Pounder_Pit Posted September 7, 2004 Report Share Posted September 7, 2004 I just installed my turbo timer and the remaining wires I have left are the blue and brown wires which said to go to the ecu, I think the ecu is on the passenger side kick panel, but which wires do I splice them into ??? Link to comment Share on other sites More sharing options...
Pounder_Pit Posted September 10, 2004 Author Report Share Posted September 10, 2004 anybody please :'( Link to comment Share on other sites More sharing options...
SFBMX88 Posted September 11, 2004 Report Share Posted September 11, 2004 sent you an email...or two. actually three. Link to comment Share on other sites More sharing options...
Pounder_Pit Posted September 11, 2004 Author Report Share Posted September 11, 2004 Thank you Link to comment Share on other sites More sharing options...
Metric-man Posted November 26, 2004 Report Share Posted November 26, 2004 I just installed my turbo timer and the remaining wires I have left are the blue and brown wires which said to go to the ecu, I think the ecu is on the passenger side kick panel, but which wires do I splice them into ??? For others seeking this info it's in the FAQ's http://www.starquestclub.com/forums/viewtopic.php?t=28044 Link to comment Share on other sites More sharing options...
860QuestTuner Posted November 26, 2004 Report Share Posted November 26, 2004 I think they are for the automatic timer based on RPM.It won't work on the quest becuase of the tach signal.They make a converter for it.Did you use the harness? Link to comment Share on other sites More sharing options...
SFBMX88 Posted November 27, 2004 Report Share Posted November 27, 2004 I did use the harness. Along with the signal converter (which is an additional $50 or so). All functions on the hks timer work. Link to comment Share on other sites More sharing options...
860QuestTuner Posted November 30, 2004 Report Share Posted November 30, 2004 Did you hoop the wire up to the e-brake.If you have a manual trani there's a wire for the hand brake,so it doesn't run in case it's in gear it won't activate unless the e-brake is on. Link to comment Share on other sites More sharing options...
SFBMX88 Posted December 2, 2004 Report Share Posted December 2, 2004 buhhh???? Yeah, I did hook it up to the E-brake switch. When the brake is set, the timer will time down. Link to comment Share on other sites More sharing options...
860QuestTuner Posted December 4, 2004 Report Share Posted December 4, 2004 ok, so if all the functions work on the timer what is your problem? Those wires could be for connecting on a different car.Some turbo timers also have a relay to work with aftermarket alarms.If it's all working then you should be all set,also if the timer has a boost alarm those wires could be for map sensor.Starquests don't have those,early models had boost a boost sensor on firewall above brake booster. Link to comment Share on other sites More sharing options...
