Quest88 Posted August 27, 2002 Report Share Posted August 27, 2002 When I first got my quest most if not all my engine wiring went to S#@*!. I guess one of the previous owners had the battery crack and let acid go all over the wiring and the fuseable links that sit in front of the relay box in the engine bay. Anyways I went to Pep Boys and bought a small fuse box replacement unit. I'll get the part number later for those who want to know. Anyways I went ahead and replaced the fuseable links with real Fuses and some of my wiring is now replaced. So hey just to let you know someone is doing something about the wiring its not that bad. ALSO I HAVE HOOKED UP A BLITZ FATT ( FULL AUTO TURBO TIMER) IF ANYONE NEEDS HELP ON HOW TO SPLICE IT IN THE IGNITION I WOULD BE MORE THAT GLAD TO HELP I KNOW THE COLORS FOR THE HOOK UP. Hardwired it up myself. Fellow Quester, Mike T. Link to comment Share on other sites More sharing options...
Sam Posted August 28, 2002 Report Share Posted August 28, 2002 Hey Mike..Part numbers and pictures would be great. Did you notice any difference on the voltmeter after you were done ?? Sam Link to comment Share on other sites More sharing options...
Quest88 Posted August 28, 2002 Author Report Share Posted August 28, 2002 Hey Mike..Part numbers and pictures would be great. Did you notice any difference on the voltmeter after you were done ?? Sam Well it started up alittle better and as far as the voltage I couldn't tell Becuase I had a real flakey alternator that I didn't replace till this year. As far as the pics go I'll have to get a scanner or a cheap a** digitial camera to get these mods up. I need to go to pep boys and get ahold of the part numbers I'll get them to ya in a couple of days. Link to comment Share on other sites More sharing options...
DJpowerHaus Posted August 28, 2002 Report Share Posted August 28, 2002 Great job.. I NEED to replace my fusable links... I replaced one with regular wire so Im looking death right in the face. How much did this fuse box go for? Also, how much was the FATT? Link to comment Share on other sites More sharing options...
Quest88 Posted August 28, 2002 Author Report Share Posted August 28, 2002 Great job.. I NEED to replace my fusable links... I replaced one with regular wire so Im looking death right in the face. Â How much did this fuse box go for? Also, how much was the FATT? The box was around 15 bucks plus the cost of connectors and fuses so I think about 22 bucks to do each fuseable link box. I only have one done becuase the other is still in good shape. The FATT I got for 85 bucks new threw a local speed shop PANN AUTO I guess it was an older model becuase they are usually around a Hundred. I'll post the part numbers as soon as I get a chance to go to Pep Boys. Link to comment Share on other sites More sharing options...
DJpowerHaus Posted January 4, 2003 Report Share Posted January 4, 2003 I'm finally getting around to doing this. I just need to know what fuses to buy. How many amps are each one? Link to comment Share on other sites More sharing options...
JamesR Posted January 5, 2003 Report Share Posted January 5, 2003 I liked to know the parts you used too. I was looking into this, but have not done this yet. I'd like to also know what fuses you used too. Here's info I got from the manual: Permissible current Link color dia. wire size in engine Other Main link black 1.25mm 16 AWG 12 amps 22 amps Sub2 #1 link red 0.85mm 18 AWG 9 amps 17 amps Sub2 #2 link brown 0.30mm 22 AWG -- 5 amps Sub2 #3 link red 0.85mm 18 AWG 9 amps 17 amps Sub2 #4 link green 0.50mm 20 AWG 7 amps 13 amps I pulled the info from chapter 8 page 12 and 8-102. What I wasn't sure was the "permissible current" section. It seems the numbers are reveresed. Check the chart on page 12 on chapter 8. Link to comment Share on other sites More sharing options...
