eldos Posted November 2, 2003 Report Share Posted November 2, 2003 I need to make a camshaft sensor for the Quest because I am using the Autronic with a MSD DIS2 ignition. I could use the old distributor to mount a trigger wheel or try to mount a sensor to the cam shaft gear. I think I will try the modified distributor. Any other ideas? Steve Denver 88 ESIR Link to comment Share on other sites More sharing options...
shift1313 Posted November 2, 2003 Report Share Posted November 2, 2003 just go to the junkyard and get a crank trigger off any ford that uses it. thats how the megaspark edis system works Link to comment Share on other sites More sharing options...
eldos Posted November 12, 2003 Author Report Share Posted November 12, 2003 I have a crank trigger wheel, but I still need to ref. The cam on Number One cylinder. A crank trigger will give you 2 pulses. One on intake and one on exhaust. I guess some other systems use an odd/even ref. so you can time just off the crank. It seems to be a down side of the Autronic. Steve Gee 88 ESIR Link to comment Share on other sites More sharing options...
Joel Posted November 12, 2003 Report Share Posted November 12, 2003 You should only need the cam trigger if you are planning either Sequential ignition or injection. I thought the autronic would support batched modes and multiple trigger types? Joel Link to comment Share on other sites More sharing options...
eldos Posted November 14, 2003 Author Report Share Posted November 14, 2003 Well, The waste spark is where it gets messy. Because you are igniting 2 cylinders at once, The ECU needs to know where number one is for the injectors. You can't take a direct signal from the ignition. I know, it crazy. Other systems are not such a pain in the @ss for setting up a waste spark system. The Basic system again is Chads intake, Autronic smc computer, and MSD DIS2 Steve Gee 88 ESIR Link to comment Share on other sites More sharing options...
Joel Posted November 14, 2003 Report Share Posted November 14, 2003 I run Wastespark and Batch fire injection with a crank trigger. It requires a twin pole trigger (one pole for sync, one for triggering). Joel Link to comment Share on other sites More sharing options...
