j.quest Posted August 19, 2015 Report Share Posted August 19, 2015 I tried the addco brackets and they fit awful,anyone know or have brackets and,bushings that will fit the addco sways ? any suggestions ? thanx Quote Link to comment Share on other sites More sharing options...
importwarrior Posted August 19, 2015 Report Share Posted August 19, 2015 GNT performance has the bushings contact them. http://www.starquest...howtopic=144493 The link to their site is in their sig. I believe the bushings work with stock brackets and come as a set for front and back. Quote Link to comment Share on other sites More sharing options...
j.quest Posted August 20, 2015 Author Report Share Posted August 20, 2015 thanx for the info. Quote Link to comment Share on other sites More sharing options...
MPGorBOOST Posted August 21, 2015 Report Share Posted August 21, 2015 GNT will take good care of you! You will also need to fab a 1/2"-3/4" spacer plate to use the stock brackets and longer bolts. Make sure they're grade 8 or better. Quote Link to comment Share on other sites More sharing options...
j.quest Posted August 24, 2015 Author Report Share Posted August 24, 2015 thanx for the info. what about using st brackets with aftermarket bushings ? Quote Link to comment Share on other sites More sharing options...
stesir Posted August 28, 2015 Report Share Posted August 28, 2015 the fronts are what do not work with ST's for our oem I just went thru this last week, I'll get you the part # you'll need Quote Link to comment Share on other sites More sharing options...
j.quest Posted August 28, 2015 Author Report Share Posted August 28, 2015 thanx that info would be super.,I bought a new set of addco brackets and bushings,front and rear and none fit,the mechanic showed me ,how off they were. at this point ,I will try any aftermarket brackets and bushings that might fit. Quote Link to comment Share on other sites More sharing options...
NotStock88 Posted August 31, 2015 Report Share Posted August 31, 2015 (edited) Here is what I did to get the bushings for the ST sway bars (now addeco?). This might work for the brackets tooLook the bars up per our application on summit.com and then scroll down and find the .pdf file for the "install instructions". On page 1 there is a parts list of what all is included along with individual part numbers. Google the part number your looking for and buy from a distributor. It's been years since I got them but that's how I found them Edited August 31, 2015 by NotStock88 Quote Link to comment Share on other sites More sharing options...
j.quest Posted September 2, 2015 Author Report Share Posted September 2, 2015 great idea!! thanx Quote Link to comment Share on other sites More sharing options...
stesir Posted September 6, 2015 Report Share Posted September 6, 2015 Prothane 19-1168-BL Quote Link to comment Share on other sites More sharing options...
j.quest Posted September 8, 2015 Author Report Share Posted September 8, 2015 great info ,thanx!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
