Tsi-1 Posted April 18, 2015 Report Share Posted April 18, 2015 Somthing is wrong wiht the Ecu in my mpi system injectors don't inject fuel on the engine everything alse is working fine the ecu flash wen I'm cranking the car I don't have any idea why don't inject fuel.. Link to comment Share on other sites More sharing options...
scott87star Posted April 18, 2015 Report Share Posted April 18, 2015 Do you have fuel pressure? Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 18, 2015 Author Report Share Posted April 18, 2015 Yes 42psi I take the injectors out and clean it and they spray really good ..Wiht the ignition on I check the injectors harnes wiht test light the 1 and 2 cilinders harnes have power and both wires red and white and the 3 and 4 cilinders only power on the red wire..😩Thanks for u help...! Link to comment Share on other sites More sharing options...
scott87star Posted April 18, 2015 Report Share Posted April 18, 2015 Swap 1&2 with 3&4 and check again. Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 18, 2015 Author Report Share Posted April 18, 2015 I swap the plugs 1&2 to injectors3&4 and the 3&4 to 1&2 and still don't star.. Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 18, 2015 Author Report Share Posted April 18, 2015 I swap the plugs 1&2 to injectors 3&4 and the 3&4 to 1&2 and still don't star.. Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 18, 2015 Author Report Share Posted April 18, 2015 I don't understed why is power and the 2 wires all time and 1&2. Link to comment Share on other sites More sharing options...
scott87star Posted April 18, 2015 Report Share Posted April 18, 2015 Did the injectors without power on both leads move to 1&2? That was my question. I didn't expect it to start. To save time, with the key on BOTH injector wires should show 12v when plugged into the injector because the ECU grounds the injectors at the ECU to fire them. If you disconnect all the injectors and measure you should find 12V on only one side. If an injector is plugged in and only one side has power with the key on it means the injector is bad. Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 18, 2015 Author Report Share Posted April 18, 2015 Ok I will Check it tomorrow morning I'm working now I let u know how they go .. Thanks a lot Scott..!! Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 19, 2015 Author Report Share Posted April 19, 2015 Scott I did what u say and wen plugs are connected have 12v and all wires red and white wen I unplug it have 12v and 1&2 and 3&4 only on the red wire .. Link to comment Share on other sites More sharing options...
scott87star Posted April 19, 2015 Report Share Posted April 19, 2015 So what you describe voltage wise sounds correct, you know they spray as you indicated above, time to look further. If the ECU light is flashing while cranking then it is getting an rpm signal, can you connect your laptop to the ECU and take a datalog of what is happening as you crank? You can get free software to connect, go to www.efianalytics.com and look for Tuner Studio, the lite version is a free download. Note that tune studio may not have a configuration file for the old FIP firmware, if that is the case PM me and I can get you something. Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 20, 2015 Author Report Share Posted April 20, 2015 Do u know what's is the diferents on the ecuF1 and f1-s..??Is anything to do the ignition adapter wiht the injectors no working ..? Link to comment Share on other sites More sharing options...
scott87star Posted April 20, 2015 Report Share Posted April 20, 2015 There is no ecu difference between F1 and F1-S, just the board. If you can take a datalog I can see what the problem might be. If the ECU doesn't see an rpm input signal it will not try to fire the injectors. Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 20, 2015 Author Report Share Posted April 20, 2015 Ok thanks Scott I have ather conquest with the F1-s is running perfec u thing I just can swap the Ecu to see if the other car star.? The Ecu f1-s is litle small then the f1.I will try to get loptop becouse I don't have one.. Link to comment Share on other sites More sharing options...
scott87star Posted April 20, 2015 Report Share Posted April 20, 2015 I wouldn't mess with swapping things, you'd have to swap the processor out as the connectors are different. Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 20, 2015 Author Report Share Posted April 20, 2015 Ohh ok well I need to buy Labtop to keep goin .I can work on the car with any laptop or has to be an espesific one? Link to comment Share on other sites More sharing options...
scott87star Posted April 20, 2015 Report Share Posted April 20, 2015 Nothing specific, just has to have a usb/serial port and you will need the cable as well. Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 22, 2015 Author Report Share Posted April 22, 2015 Hi Scott do u know if the timing change with the mpi or is the same is stock 10 before dtc.? Link to comment Share on other sites More sharing options...
scott87star Posted April 22, 2015 Report Share Posted April 22, 2015 Timing is the same. Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 28, 2015 Author Report Share Posted April 28, 2015 Scott I can fine anything for fIP and tuber studio .. Link to comment Share on other sites More sharing options...
Tsi-1 Posted April 28, 2015 Author Report Share Posted April 28, 2015 I can't fine anything . Link to comment Share on other sites More sharing options...
