C300 Posted April 9, 2015 Report Share Posted April 9, 2015 The local Mits Dealer Doesn't have the Manuals "back that far" anymore. Need P/N to order it. Was a time I new it by hart. they don't last. Need the Thermosensor No 1 Part Number. Do you guys use the OEM, or is there a better one out there ?The 4 i have are opening between 196 and 206. so temp is about 195-210 until moving. No. 2 is stock original, and kicks on about the same time as the aftermarket No 1. thanks, C300 Link to comment Share on other sites More sharing options...
pcristquester Posted April 9, 2015 Report Share Posted April 9, 2015 Download and open the parts locator and check in the cooling section Link to comment Share on other sites More sharing options...
importwarrior Posted April 9, 2015 Report Share Posted April 9, 2015 www.starquestgarage.comCooling Section 7 MB007639 passenger sideMB435745 Driver side i got mine from Summitracing.com Link to comment Share on other sites More sharing options...
C300 Posted April 11, 2015 Author Report Share Posted April 11, 2015 (edited) Thanks for the info. I have the MM for the 86 and 88 downloaded. no Parts Manuals, so no P/N's. Should start calling this the "Classic starquestclub" since they aren't listing then anymore. will Download the IPC's. here's some info i found. looked Russian before i converted it. The low temp. passenger side one listed says it's for the 1983-1984 cars. Comes on at 185 degree Fahrenheit. Good info, lowest on temp stock. I have only ordered '85 ad up, being the models i've owned, Thanks again, C300 No PNC # OEM part number Count on one machine Title Specification Note Color Production period Condition Classification Under the order In stock 1 10322 MB007639 01 SENSOR, RADIATOR WATER TEMPERATURE ON-85 1983.08.1 - 1984.09.3 ALL < 2 10322 MB356842 01 SENSOR, RADIATOR WATER TEMPERATURE ON-90 1986.01.1 - 1986.09.3 SRHWG <TOURING EXCEED, 4FA / T 3 10322 MB435745 01 SENSOR, RADIATOR WATER TEMPERATURE ON-100 1986.01.1 - 1986.09.3 SRHWG <TOURING EXCEED, 4FA / T 4 10322 MB356842 01 SENSOR, RADIATOR WATER TEMPERATURE ON-90 1986.10.1 - 1987.09.3 ALL < 5 10322 MB435745 01 SENSOR, RADIATOR WATER TEMPERATURE ON-100 1986.10.1 - 1987.09.3 ALL < Edited April 11, 2015 by C300 Link to comment Share on other sites More sharing options...
C300 Posted April 11, 2015 Author Report Share Posted April 11, 2015 www.starquestgarage.comCooling Section 7 MB007639 passenger sideMB435745 Driver side i got mine from Summitracing.com Tech From Summit Racing said they can order the sensors from some company. they don't do OEM stuff, so they aren't in the catalog. $45 each. he doesn't have the spec's on them, just left N right sensors. so there's no telling what the ON-Temp. is I have 10 sitting here that open too late. and at $50 each it's pissing me off ! Thanks for the info !, C300. Link to comment Share on other sites More sharing options...
C300 Posted April 11, 2015 Author Report Share Posted April 11, 2015 P/N Summit quoted me. This is what i'm talking about. says it opens at 85-80C. but 3 part #'s are mixed together. and say 100-95C. by the way, these are listed as NO LONGER AVAILABLE from this particular Factory, C300 http://g01.a.alicdn.com/kf/UT8gs5FXj4bXXagOFbXU/206036469/UT8gs5FXj4bXXagOFbXU.jpg Link to comment Share on other sites More sharing options...
