donplayahat Posted January 5, 2015 Report Share Posted January 5, 2015 I am looking for the head light switch with the harness, the one that goes in the dash on the left side. mine is not working and it has drained my battery countless times even thou the lights seem to be "off" please let me know if anyone has it. I live in charlotte NC. Car 1988 conquest TSI Quote Link to comment Share on other sites More sharing options...
donplayahat Posted January 6, 2015 Author Report Share Posted January 6, 2015 bump Quote Link to comment Share on other sites More sharing options...
vbrad511 Posted January 7, 2015 Report Share Posted January 7, 2015 I've probably got one, but are you sure it's the switch draining your battery. Occasionally the alternator loses a diode which will cause a small load and drain them. PM me if I can help. Quote Link to comment Share on other sites More sharing options...
DSMracespeed Posted January 7, 2015 Report Share Posted January 7, 2015 You can disconnect the switch and see if it still draining your battery. Jerry L. Quote Link to comment Share on other sites More sharing options...
donplayahat Posted January 7, 2015 Author Report Share Posted January 7, 2015 its the switch. its stuck on the "on" position. my headlights are up and wont re-track down. thanks for the advice thou. Quote Link to comment Share on other sites More sharing options...
prototype78 Posted January 8, 2015 Report Share Posted January 8, 2015 (edited) Do you disconnected both livht switches on cluster hood?!...both switches needs to be connected for headlights go down also you might want to check under dash a right side of radio theres 2 plugs for headlights too...if they are disconnected they wont down but light will turn on dimmer can be disconnected and still would work sometimes you gently tap the light on switch and will come down if you have everything connected Edited January 8, 2015 by prototype78 Quote Link to comment Share on other sites More sharing options...
markhansenconquest Posted January 8, 2015 Report Share Posted January 8, 2015 (edited) plastic is broke inside take apart and super glue back together .....fixed 2 that way...the plastic button on the inside breaks ..............if u cant find the broken piece ...put super glue where it broke and file it back it to shape...!!!!! don't loose the springs and clean all the contacts while u are there.!!!!!!! use a dab of die electric grease after cleaning contacts........ Edited January 8, 2015 by markhansenconquest Quote Link to comment Share on other sites More sharing options...
sn8kes Posted January 17, 2015 Report Share Posted January 17, 2015 Pm'd Quote Link to comment Share on other sites More sharing options...
donplayahat Posted January 19, 2015 Author Report Share Posted January 19, 2015 Thanks, for the replies. I already purchased one. Thanks vbrad511 Quote Link to comment Share on other sites More sharing options...
