Building AN Fuel Lines in the Engine Bay
Starion86ESI
Why not run a line from the 044 all the way up to the rail and another back for the return? I believe inlet side of the 044 is M18x1.5 and outlet is M12x1.5. I'll double check my fittings
Metric to AN adapters to -6 or -8. I was right on the sizes. If you want to be filtered run an AN inline fuel filter after the pump and the pre pump fuel everybody recommends
http://jdlautodesign.net/wp-content/uploads/2014/03/bosch044fp.jpg
Edited by RonnieJ
I think you could get some hose and replace the stock one easily if that's all you're trying to do. If you want AN lines for decoration, then for best results with a stock-style fuel setup, I suggest all -6 stuff.
