neohioquest Posted October 30, 2012 Report Share Posted October 30, 2012 Okay, I have a friend that gave me a garrett turbo charger and I am trying dearly to find out what it came off of and if it could benefit me. I will start with the specifications. The turbine is a T3 housing with an a/r of .36 as far as I can tell. It is kind of hard to see. The turbine wheel is as follows. Inducer 64.4mm (2.5in) and Exducer 45.9mm (1.8in.) The compressor is a to4d I beleive and has an a/r of .50 The wheel is, Inducer 46.5mm (1.83in) Exducer 60.14mm (2.3in) I did some research as to just the size of the compressor wheel and it is the same as a 16g. I cannot figure out what this turbo is off of. I dont think it would be very efficiant on our car because of the very small turbine housing. Haha it would have extremely quick spool but be good for about 3k maybe. Anyways I have another turbo I was thinking about using to combine the compressor of this turbo with the turbine of the other one. The turbine of the other one has an a/r of .63 and the wheel measures Inducer 52.7mm and Exducer 75.4mm. Any thought on what the first turbo could be off of and also thoughts on if that would be a good option? Link to comment Share on other sites More sharing options...
creakyjoints Posted October 30, 2012 Report Share Posted October 30, 2012 What part number is on the center housing tag? Link to comment Share on other sites More sharing options...
neohioquest Posted October 30, 2012 Author Report Share Posted October 30, 2012 There doesn't appear to be a tag on the center cartrige anymore. Link to comment Share on other sites More sharing options...
neohioquest Posted November 7, 2012 Author Report Share Posted November 7, 2012 Anyone else have any info or ideas here? Link to comment Share on other sites More sharing options...
Skullzaflare Posted November 7, 2012 Report Share Posted November 7, 2012 what are you measuring? on the compressor wheel, the smaller section of the wheel is the inducer, and the larger section is the exducer. sounds like you measured the inlet and outlet Link to comment Share on other sites More sharing options...
neohioquest Posted November 8, 2012 Author Report Share Posted November 8, 2012 I had the housings off of the CHRA. Those measurements are correct. The hose size for the tube is 3in and the outlet is 2in. Link to comment Share on other sites More sharing options...
