89questzilla69 Posted July 4, 2011 Report Share Posted July 4, 2011 ok guys jus put motor in this car and it starts great and revs great sitting when i drive the car though if i feather the gas i can get it to rev better if i get into the gas pretty good it falls on its face @ 3k and wont go no higher Link to comment Share on other sites More sharing options...
marso Posted July 4, 2011 Report Share Posted July 4, 2011 (edited) Check your secondary injector pins and connector contacts are clean. Check the fuel pressure and if filters are clogged. Edited July 4, 2011 by marso Link to comment Share on other sites More sharing options...
89questzilla69 Posted July 4, 2011 Author Report Share Posted July 4, 2011 checked inj. and wiring got pulse and power changed the injectors still same issue Link to comment Share on other sites More sharing options...
89questzilla69 Posted July 4, 2011 Author Report Share Posted July 4, 2011 this is an 86 starion Link to comment Share on other sites More sharing options...
Indiana Posted July 4, 2011 Report Share Posted July 4, 2011 Your vacuum advance working? http://www.b2600turbo.com/distributorvacuum_advance_unit.htm Pull the cap, put a short piece of hose on then suck on it and watch the arm pull in then cover the tip of the hose with your tonque and the arm must stay in otherwise its bad and its not able to retard timing under boost. Link to comment Share on other sites More sharing options...
marso Posted July 5, 2011 Report Share Posted July 5, 2011 Check the advance springs also they broke on the 86 I had and was in full advance all the time. It would pop and fall on it's face a little above 3k. Do you have a Fuel Cut Defenser it makes a big difference. Link to comment Share on other sites More sharing options...
89questzilla69 Posted July 10, 2011 Author Report Share Posted July 10, 2011 vac adv. is deleted Link to comment Share on other sites More sharing options...
Indiana Posted July 10, 2011 Report Share Posted July 10, 2011 vac adv. is deletedThere's your problem you can not remove that it must be there and working unless you have a way to control ignition timing with a stand alone device. Did you look at the link I posted? Link to comment Share on other sites More sharing options...
StarquestRescue Posted July 10, 2011 Report Share Posted July 10, 2011 ok guys jus put motor in this car and it starts great and revs great sitting when i drive the car though if i feather the gas i can get it to rev better if i get into the gas pretty good it falls on its face @ 3k and wont go no higher this is an 86 starionOn my 85.5 turbo truck i could hit fuel cut around 11-12 psi with just a 2.5 exhaust. Link to comment Share on other sites More sharing options...
89questzilla69 Posted July 11, 2011 Author Report Share Posted July 11, 2011 john this dont seem like fuel cut but i dunno ive tried a couple diff. ecu's in car and still the same ...indiana on my 88 i deleted vac adv and it ran fine 21 lbs 17 deg. of timing ran 13.7 at track no hickups and it was there w/ the vac adv hooked up also Link to comment Share on other sites More sharing options...
Frenchi934 Posted July 12, 2011 Report Share Posted July 12, 2011 you cant be serious about deleting the vacuum advance..... it not only advances timing, but also begins to retard it. without it under boost you car will knock and the knock sensor will have to detect, and pull timing to keep your car from tearing itself to shreds. I believe some of you might be confused about what vacuum advance is if you think you have successfully deleted it. (unless youre running megasquirt and EDIS or some alternate type of timing advance) Link to comment Share on other sites More sharing options...
