TheWormForEver Posted May 27, 2011 Report Share Posted May 27, 2011 My instrument panel lights went out, I cant seem to find any blown fuses. My headlights still work fine, it's just the instrument panel lights went out while i was driving, they haven't come back on. What should I be looking for? Link to comment Share on other sites More sharing options...
vbrad511 Posted May 27, 2011 Report Share Posted May 27, 2011 (edited) How about your ac panel. Does the display work with the lights off? Lights on? Possible a dirty headlight switch, but the best bet, the dimmer by your left knee. Edited May 27, 2011 by vbrad511 Link to comment Share on other sites More sharing options...
carguygibby Posted May 27, 2011 Report Share Posted May 27, 2011 The dimmer switch is usually the culprit. Link to comment Share on other sites More sharing options...
Wakeman17 Posted May 27, 2011 Report Share Posted May 27, 2011 If your instrument panel lights just went out all of sudden, then that means your tail lights arent working either. Check the fuses again it should be the one for the tail lights because they are on the same fuse. I think its on the left side of your cockpit fuse panel. Should be a 15a. If thats not it then im not sure. Link to comment Share on other sites More sharing options...
Shelby Posted May 29, 2011 Report Share Posted May 29, 2011 90 % of the time it's the dimmer control,, if you check the diagram you'l see it's only a ground control,, jumping the swt with a jumper to make ground with make lamps work but you will not long have any dimmer control,,most use full brigth any way Link to comment Share on other sites More sharing options...
