MSD blaster 2 coil
nicksquest
It must be the one for electronic ignition, there are two and they look the same so read the labeling. Stock there were two wires on each side:
Black wire w/white stripe from your harness, this is the power wire from the ignition switch.
There's a noise filter, its a black tiny thing about 1" square and it has two wires from it, one is blue and this goes to the coil and the other end has a plug on it. It plugs in to a short pigtail that is bolted under one of the EGR valve mounting bolts. This item is not necessary but you may leave it connected for its benefits.
Blue wire w/white stripe from your harness, this is the tach signal back to the ECU.
There is a resistor with two wires from it, one is black and it goes to the coil and the other is white with a plug on the end. That plugs to a wire in your harness and its the tach signal for the instrument cluster and this is necessary.
  • 2 weeks later...
yes, it is the electronic and i have 4 wires going to the + and 1 going to the -. here is a video of what i got she is an 87: http://www.youtube.com/watch?v=0l_6ARMwKos
http://i139.photobucket.com/albums/q299/I-W/Quest%20Parts%20and%20info/Coil-1.jpg
http://i139.photobucket.com/albums/q299/I-W/Quest%20Parts%20and%20info/coil-2.jpg
wow, thank you this may be why i keep killing alt's the prev owner put that in so he said i will be sure to do it the right way when i get home from work tomorrow!!
