TERRY53 Posted June 11, 2010 Report Share Posted June 11, 2010 while reading voltage at gw wire. only getting one volt. to set tps. does it require to open throttle fully open. to adjust to 4.8 volts. only time getting 5 volts is with throttle fully open. Link to comment Share on other sites More sharing options...
Starwolf Posted June 12, 2010 Report Share Posted June 12, 2010 Okay to talk about the tps...mine actually only reads a max of .44v with throttle at idle position. With wot it shows 4.99v. I am still unclear if this is just from a bad tps or what. 5v is what you are supposed to get at wot and .5v at idle position for TPS. Link to comment Share on other sites More sharing options...
TERRY53 Posted June 12, 2010 Author Report Share Posted June 12, 2010 Okay to talk about the tps...mine actually only reads a max of .44v with throttle at idle position. With wot it shows 4.99v. I am still unclear if this is just from a bad tps or what. 5v is what you are supposed to get at wot and .5v at idle position for TPS. Link to comment Share on other sites More sharing options...
TERRY53 Posted June 12, 2010 Author Report Share Posted June 12, 2010 tested voltage. engines cold.. idle 0.2 volts wot 4.5 volts Link to comment Share on other sites More sharing options...
Starwolf Posted June 12, 2010 Report Share Posted June 12, 2010 Was this with the TPS all the way to the right (clockwise)? Like i said mine turned all the way clockwise only shows .44v and at wot it shows 4.99v Sounds like you have a bad tps if thats the case. Have you tried a sweep test? Link to comment Share on other sites More sharing options...
TERRY53 Posted June 12, 2010 Author Report Share Posted June 12, 2010 Was this with the TPS all the way to the right (clockwise)? Like i said mine turned all the way clockwise only shows .44v and at wot it shows 4.99v Sounds like you have a bad tps if thats the case. Have you tried a sweep test? ok. found part of the problem. wrong meter. was not reading voltage that low.. thanks.. got it set to 0.50.. .. ran it.. an lost the setting. screw were not tight enough.. thanks terry Link to comment Share on other sites More sharing options...
WARPSPEEDER Posted June 16, 2010 Report Share Posted June 16, 2010 wondering if this will also keep the Quests from starting too if it's too far off? Link to comment Share on other sites More sharing options...
Indiana Posted June 17, 2010 Report Share Posted June 17, 2010 no Link to comment Share on other sites More sharing options...
