Dad Posted April 27, 2006 Report Share Posted April 27, 2006 This is how we prime an engine after rebuild. You may want to get one of these if you do quite a few engines, or make you own Here is the tank. http://www.enginemachineservice.com/prime2.jpg We attach the hose to the front fitting of the block.... http://www.enginemachineservice.com/prime4.jpg http://www.enginemachineservice.com/prime1.jpg The tank is filled with oil then pressurised to 100-120 lbs shop air. There is a valve on top to release the pressurised oil.. as you can see oil is fed untill you no longer see any bubbles from the rockers. This will also prime the oil pump. http://www.enginemachineservice.com/prime3.jpg I did have to rig up some plugs for the oil cooler fittings and turbo feed line to plug them off. This works great in the car as it will prime the turbo and fill the oil cooler and lines BEFORE ENGINE START UP. Just thought I'd let you know. Dad Link to comment Share on other sites More sharing options...
T_sandman Posted April 28, 2006 Report Share Posted April 28, 2006 I almost feel like you made this thread just for me. I'm right there on my motor. Where can one purchase such a thing and about how much would one expect to pay sir? Nice. Link to comment Share on other sites More sharing options...
Dad Posted April 28, 2006 Author Report Share Posted April 28, 2006 I almost feel like you made this thread just for me. I'm right there on my motor. Where can one purchase such a thing and about how much would one expect to pay sir? Nice. Silver sealhttp://www.silver-se...me/2003_SIL.PDF page 14 or 15 I think it was about 130.00 well worth it for a shopDry start ups can kill an engine.Even cranking dry does not help them Dad Link to comment Share on other sites More sharing options...
Dad Posted April 28, 2006 Author Report Share Posted April 28, 2006 You can also make a tank, just be sure it is CLEAN. need a place to install oil, ball valves can be installed at the bottom to feed oil. Air fitting to add pressure. Just be sure to close off the valve before tank empties to prevent air from entering the engine. Dad Link to comment Share on other sites More sharing options...
