MAF-T tuning hope this helps someone out.
From Scott87star
This is what a Stock Quest showing what the readings are from a wideband O2 Sensor.
Quote:
I did for several years on a perfectly running Starion. Idle SHOULD BE 12.5-13.5 if the nose switch is working correctly, if its not sending the ground signal it will hunt around 14.7. Under boost it drops to 12 and in cruise you can watch it hunt from 14.4-15.2, back and forth.
The lookup table for the MAF output is 5X7 or 35 tuning points.
END Quote:
I wanted to tune the maft t using the stock wide band readings from a stock quest.
Since I tuned my car with the settings that Scott provided above it has ran perfectly.
Every car is different and you need to be careful when tuning and boosting.
This is not for installing only tuning.
MAF-T tuning guide download link.
MAF-T versions
http://www.fullthrot...isplay.php?f=40
specific car types MAF-T Guides
http://www.fullthrot...isplay.php?f=66
1st Gen 2nd Gen Eclipse Guide
http://www.fullthrot...hread.php?t=894
Tuning the MAF-T
1st select the proper GM MAF sensor your using per the guide.
On the MAF-T you have 5 dials
BASE, AUX, IDLE, MID, WOT,
Once you have the proper setting for the MAF sensor now you have to set the
BASE and AUX settings for your injector size per the Guide.
Take the 2 injectors your using and add them together, Then divide by 4.
EXAMPLE:
650 + 1050 = 1700 CC / 4 = 425
Set the MAF-T to 430 cc injector setting.
Per the 1st GEN MAF-T Guide injector setting section.
The Guide states that the 1st GEN setting BASE 0 – AUX 0 = 430 CC injector settings.
START the CAR
Using the wideband gauge you need to adjust the IDLE dial to get the car to idle at
12.5 to 13.5 on the Wide Band Gauge.
The other dials are set to 0. MID and WOT
Rev the car a few times. Make sure it does not stall.
Drive the car,
Find a road that is not busy. Drive the car at 35 to 40mph.
You want a constant cruising speed. Keep an eye on the WB gauge.
You want the gauge to be around 14.4 to 15.2 during this constant
cruising speed. If it is rich or lean adjust the BASE dial leaner or richer
accordingly. You want the wide band gauge to read 14.4 to 15.2 at a continuous cruising speed.
i have changed gears from 3rd to 5th and maintained the speed at 40 and the gauge read the same.
Once you achieve this with consistency, now you will have to recheck your
Idle and again adjust the IDLE dial so the wideband at idle is 12.5 to 13.5.
Now that your IDLE and Cruise is set, you will start to give the car some light boost.
¼ to mid throttle. Light acceleration not much boost.
As you touch the gas pedal and start to accelerate. The tip in
on the gauge might go rich or lean. Now you adjust the MID DIAL.
Adjust it so that your light acceleration is near 12.5 to 13.0. You will have to
Adjust to see what is best for your cars setup you might need it richer. Once you
can transition from Cruise to light throttle acceleration and it pulls nicely the MID dial
is for when the car transitions to boost. if it bogs here as you go from steady cruise to
light boost the mid dial fixes the rich or lean stumble as you press the gas or tip in.
this is for light throttle. the mid is for when you want to give it a 1/4 or 1/8 of more pedal.
5 PSI or less kind of adjustment.the transition to WOT. dumps a little extra fuel.
WOT Dial
Just what it says. Once the car runs good you will full boost the car and
have your co pilot check the gauge. Make sure the wide band gauge
is around 11.3. Adjust the WOT Dial accordingly.
In my opinion the MAF-T is a sloppy tuning tool. Only 5 % increments per click.
Unless you get the RPM signal hooked up then you have 2% increment adjustments.
Read the guide on how to use that.
On a side note I had trouble getting the wideband gauge to read 11.3 to 11.5 on
Wide OPEN Throttle with my car. My car was running 10.4 on my wideband gauge.
If I adjusted the MAF-T WOT DIAL one click lean. The Wide band was reading
12.xx. what I was able to do on my car was adjust the fuel pressure to 41 PSI.
My car has an adjustable fuel pressure regulator. Then I retuned the car and now
was able to get the car to a nice 11.3-11.5 reading on the gauge.
Because my MAF-T is in the engine bay, I had to pull over many times and make
Adjustments to the MAF-T. some tuning steps may need to be repeated. ALSO as
the weather changes you might notice that the car might need to have some adjustments.
Seasonal changes might be necessary.
I hope this helps someone out.
Edited by importwarrior
to add to the above:
when you set the BASE and AUX settings you might
be around a 430cc injector size. When you go out
and drive the car at a constant 40 MPH, you will pull
over and adjust the BASE DIAL to try and achieve the
14.4 to 15.2 cruising Wideband setting. Once you get
the car steady at the range of 14.4 to 15.2 at cruise,
the actual Base setting will not be set at the 430cc
injector setting. The injector setting will be different.
it could be 500cc or higher. that is expected. Do not
be alarmed or surprised.
once AUX and BASE are set now adjust the IDLE DIAL
to as above settings.
glad to help.
If you feel i made a mistake and or wrong statements
please post here what you would do or recommend differently.
Thanks for your feedback and help.
  • 3 months later...
Just an update:
I had a hiccup and or detonation problem when i was crising and would press the pedal.
Kind of like when you want to give it some gas to boost but not shift to a different gear.
The car would seem to buck and load up then detonate - misfire.
What i did to fix this i just adjusted the BASE knob one click at a time untill it went away.
i did not change any other dial or adjustment knob.
Summary:
BASE adjustment– this 16 position (0-F) dial is used to set the general airflow scaling.
This adjustment affects the entire operating range of RPM and is generally used
to match the Translator and MAF to the selected injector size.
This BASE adjustment adjusts the entire fuel curve from idle to WOT max rpm as if it is just one
solid curve. The overall span from idle to max RPM will be richer or leaner with the BASE
adjustment knob -dial.
So if you are cruising at a steady pace then lightly press the gas and the 02 sensor goes too lean
adjust the base knob to try and fix the what I refer to as "TIP IN".
You might need to adjust the idle again but this will fix the tip in lean out on the car when it transitions to boost.
  • 1 month later...
Found this info form an older post.
Here is a complete list of the connections from a 87 - 89 MAS plug to a MAF Translator connection. In case you have cut your wiring from a previous MAF install, or want to solder the wires together for a better connection.
87-89 MAS plug-------------------------------------------Wire colors on MAF-T
1 - Green/red#2 - (5V)-----------------------------------NC (no connect)
2 - Red - (battery +12V )--------------------------------Pink (+12VDC)
3 - White/black - (AFS)----------------------------------Green (Translator frequency signal)
4 - Green /red #1 - (Intake Temp)-----------------------Brown (Intake Temp)
5 - Black/white #3 - (Barometric pressure)------------Gray (Barometric Pressure)
6 - Black/white #4 - (Ground)----------------------------Black (Ground)
It's been discussed within many different post topics but I wanted to specify it completely for easy connecting. Also, here is the 87-89 MAS Plug pinout.
| 1Power | 2Power | 3Air Sen. |
| 4Temp. | 5Press. | 6Ground |
Hopefully this helps someone with cut wires and no DSM 1G MAS to compare against.
