EMS STINGER with all ancillaries
EVOMINUS
For Sale is my EMS Stinger ECU with harness and all the peripherals. It consists of the main ECU, Wiring Harness, Two Coil Igniters (One per two cylinders), BOSCH Wideband Lambda, EMS Digital full display screen, Water Temperature Sensor, BOSCH Fuel Pump Relay, ECU to PC Cable(Serial), CD with EMS software.
Everythng is barely used(approximately 15 hours mainly on the dyno).
The harness is bolt on for a six bolt 4G63 but it can be very easy adapted to any engine type.
Suitable for engines with up to 8 cylinders
General Specifications
  • 4 Injector Drivers
  • 4 Ignition Drivers
  • 4 General Purpose Output Drivers
  • 1 Digital Inputs.
  • Magnetic or Hall Cam and Crank Input
  • High RF suppression.
  • Low heat generation.
  • Waterproof connector with gold plated contacts.
  • Case material is durable anodized aluminium.
  • Surface mount component circuit design.
  • Temperature range -40 to 85 Celsius.
  • Operating voltage 6 – 25 Volts.
  • Reverse Battery Protection
Computer Software
  • Real-time online tuning
  • Tune Analyzer.
  • Data logging and analysis software.
Ignition
  • Full Sequential ign (coil-on-plug)
  • Directly connect to most OEM ignition systems
  • Programmable ignition dwell
  • Timing accuracy / resolution 0.2 degrees
  • Dual 32X21 user definable tune maps.
  • Dual Map trim control.
Injection
  • Automatic battery voltage compensation.
  • Injection resolution is 2 micro seconds.
  • Automatic Staged injection activation.
Trigger Sensors
  • Compatible with most OEM trigger systems.
  • Magnetic, hall or optical cam & crank inputs.
  • Automatic magnetic sensors calibration.
  • Selectable trigger patterns for most engine manufacturers.
Input Sensors
  • 5 Standard inputs
  • 1 programmable digital inputs.
  • 1 Wide band lambda inputs
Output Drivers
  • 4 Selectable PWM / Digital. e.g. boost control.
Special Functions
  • Closed Loop lambda control.
  • Dual mode turbo anti lag (Drag or Rally).
  • Dual mode RPM Limit (hard and soft).
  • Two-Step rev limiter.
  • Nitrous oxide control.
  • Engine load idle-up control. (air con, power steering)
  • Programmable sensor calibration tables.
  • Acceleration enrichment.
  • Deceleration fuel cut.
  • Cold start and Warm start compensation adjustment.
Data Logging
  • Unlimited logging to laptop computer.
  • User selectable ECU parameters to log.
  • Log to the EMS Plug n Play Mini Data Logger.
Price: $1350
I can email photos
I can ship everywhere.
Please contact me for shipping costs
please sent me your email and i will post some for you..
the pics are way too big for the site...
The car only started when we went through maps from an evo6 my programmer had some time earlier dynoed
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
