O2 sensor
Started by allen405, May 10 2012 09:53 PM
8 replies to this topic
#1
Posted 10 May 2012 - 09:53 PM
How can you tell if it's working or not?
"the average man dies at 25 and is buried at 65" Ben Franklin
"Dude, is that a Nissan?"
Don't crush'em, restore'em
Latest pic 8/11/11>>
#2
Posted 11 May 2012 - 06:58 AM
If the ECU is throwing the trouble code for the O2 when the engine is fully warmed up then its not.
Now selling true plug and play megasquirt!
Performance Coatings! Pistons, manifolds, bearings and more!
Visit my vendor forum at http://www.26liter.u...board,48.0.html
#3
Posted 11 May 2012 - 11:39 AM
Ok, thanks. Next question what is the shielding for on the wire that goes all the way into the cab? because some of mine is missing
#4
Posted 11 May 2012 - 12:12 PM
allen405, Yeah if you can pull the codes you'll know. I mean i check mine every morning when i start it since i have a led hooked up. I check it down the road later and when the light is on and not blinking (single blink)...well then i know it's working. If it hasn't stop blinking then i know i need to replace it. If you havne't hooked up a light to where you pull the codes i recommend it. Saves you time and you can check for any code that shows up.
#5
Posted 11 May 2012 - 01:27 PM
gig out
Edited by DMNDSTAR87, 11 May 2012 - 01:30 PM.
www.whitelineus.com87 ESI-r--Ported/polished Marnal Njv head,ARP studs,JE 040pistons,+1mm s/s valves,h/d springs,match ported intake to T/B and head,52mm ported t/b and inj mixer,1000cc primary +3- 550cfm secondaries with 2 inj mounted in OVCP powered by Versafueler,274h cam,Spearco 3.5" intercooler w/custom/relocated hardpipes,msd 2222 rrfpr, HKS turbo xs bov mounted in upper I/C pipe,MBC,h/v oil pump,bosch f/p,TDO5 19c,extrudehoned exhaust mnfld,lc-1 wdbnd,OVCP mounted 3"gm mas w/maf-t,AEM filter,bosch coil,BSE kit,lightened flywheel,TEP race clutch,Tep front/rear strut bars,s/s hoses,A/C delete,ABS delete,EGR delete,cruise delete,relay relocation,Custom painted suspension all around,Whiteline bushings all around,MK1 adj. camber plates ft/rr,ST lwr springs and swaybars,slotted rotors,s/s lines and bla bla bla----custom undercarriage restoration nearing completion---
#6
Posted 12 May 2012 - 09:47 AM
Where do I get a led light with wires on it and how do I hook it up?
#7
Posted 13 May 2012 - 08:35 AM
gig out
Edited by DMNDSTAR87, 13 May 2012 - 08:35 AM.
#8
Posted 13 May 2012 - 11:56 AM
#9
Posted 14 May 2012 - 06:29 AM
Thanks, I picked one up at advance auto.
