SFBMX88 Flatty build
2008ls swap s13 rack smog legal flatty 5 lug shortened struts 6 speed auto to manual
113 replies to this topic
#1 SFBMX88
SFBMX88
  • 1,543 posts
Posted 12 March 2012 - 12:13 PM
This is mainly going to be a summary of pictures on the flatty since Memorial day, May 2008(when I picked it up).
1986 Dodge Conquest Flat sider - Non-intercooled, automatic, open differential goodness!
May 2008:
Next to my friends '87
Getting ready for some 5 lug and LSD from my scrapped '88
Edited by SFBMX88, 03 October 2018 - 09:55 PM.
#2 SFBMX88
SFBMX88
  • 1,543 posts
Posted 12 March 2012 - 01:31 PM
June 2008:
Most all of the suspension made its way onto the flatty.  Diff/axles/front and rear struts/control arms/sway bars....
Slowly cleaning up the engine bay...
Cleaned up the rusted battery tray...
4 lug wide body!
Getting ready to go...
Farewell...
Autopower cage I pulled from my $650 87 parts car:
#3 SFBMX88
SFBMX88
  • 1,543 posts
Posted 12 March 2012 - 02:59 PM
July 2008:
Automatic to Manual....
Upper clutch pedal assembly mount - I didn't have a welder at the time, so I drilled holes and bolted it in...
Automatic brake pedal....
Manual brake pedal...
The old slush box..
88 trans/ARP flywheel bolts/ACT clutch:
Auto shifter hole:
New hole:
Master cylinder and reservior:
Old TEP(spearco) radiator with 2 12" Mr. Gasket fans I saved from my 88:
Built up a harness(my wiring has gotten much better since :P )
#4 SFBMX88
SFBMX88
  • 1,543 posts
Posted 12 March 2012 - 03:03 PM
More July 2008:
Picked up another set of SHPs with brand new Hankook RS-2s:
#5 89BananaQuest
89BananaQuest
  • 625 posts
Posted 12 March 2012 - 04:27 PM
I like.  Good work man!  How hard was the trans swap?  What did u do for the cross member?  Im doing one now.
#6 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,332 posts
Posted 13 March 2012 - 04:08 PM
Flatty Love :wub:
          MOPAR POWERED
#7 randy
randy
  • 4,092 posts
Posted 13 March 2012 - 07:58 PM
That's looking ripe.
#8 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 12:32 AM
I mounted from the original auto trans mount in the tunnel to the manual trans.  It was crude at first, and still is I think, but it works.  Now that I have access to a welder, I should revisit this...
So sloppy...
The original mounts I did above flexed way too much.  I eventually corrected this(I'll post pics later).
There should be an auto to manual thread here somewhere.  It showed different methods of mounting.  I think someone actually welded mounts to the tunnel so the manual trans crossmember bolts straight to it.
Edited by SFBMX88, 14 March 2012 - 03:54 PM.
#9 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 12:34 AM
August 2008:
AC partially deleted, alternator bracket off a D-50 pick up.Posted Image
#10 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 10:27 AM
February 2009:
Taking some measurements........
#11 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 11:04 AM
March 2009:
ARP front wheel studs(100-7712) - the backs have to be trimmed down a bit to fit the 5 lug hubs.Posted Image
Rear ARPs(100-7717) - Easy install, no modifications needed.
Some Blox aluminum lug nuts:
More measuring......
Edited by SFBMX88, 14 March 2012 - 11:05 AM.
#12 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 11:16 AM
April 2009:
Rebuilt the transmission mount so it doesn't flex anymore.  A friend welded it up later on, but I think I should re-engineer it now that I have a welder handy...
Leading edge of the mount:
From the back side:
Made a gauge panel out of some Lexan.  I wired up a harness with a connector in case I ever have to pull the dash(which I have many times since):
Pumping out mid-16 second runs at Infineon  :)
#13 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 11:35 AM
May 2009:
Painted the turbo heat shield with some BBQ grill paint.  It dried looking matte black:
Still pulling strong vacuum :)
Slow build of my front coil overs:
TechnoToyTuning camber plates
KYB AGX FRONT Celica Alltrac struts
Picked up some 88-89 Toyota Celica FRONT strut housings.  They must be 88-89 as the threaded portion has the matching threads to the AGX gland nuts.
Peeks out the top:
Cut the tops off the Celica housings...
Insert in the FRONT Starion housing:
Had to space the insert from the bottom a bit:
The first attempt wasn't so great.  I didn't get the Celica tops to align to the Starion housings straight enough.  A solution came later...
My neighbors Celica Supra:
Some foreshadowing....
Threw in a used fuse link box after the original melted.  Cleaned up the terminals/connections and installed.
Edited by SFBMX88, 14 March 2012 - 11:37 AM.
#14 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 11:42 AM
June 2009:
Detailed short stroke build: http://www.starquest...opic=93736&st=0
Started on the REAR housings.  Cut the adjuster knobs out and patched over them with metal scraps from the front struts:
Installed a new thermostat.  Pulled the original Mitsubishi thermostat and installed a Stant.  Next thermostat change, I'm going back to OEM.
Back to coil overs...
Picked up some poly bump stops for a Mustang application(4.6104R - Energy suspension)
A friend turned down a set of Celica tops for me in his machine shop class.  This solved the alignment issue between the Celica tops and Starion strut housing.  They slide right in!
Welded up :)
A little black paint...
Usable suspension travel...
Edited by SFBMX88, 19 June 2012 - 04:11 AM.
#15 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 12:18 PM
July 2009:
I didn't like the metal to metal contact of the spring hat to the camber plate, so I picked up some thrust bearings and races from Mcmaster.com:
Also got a set of MK1 silicone hoses.  One hose didn't match, but I made it work.  Still no leaks to this day.
Some pics from the Treasure Island old school meet...
***coverage:  http://www.starquest...showtopic=94524
           http://clunkbucket.com/treasure-island-vintage-bonanza/
     http://www.supraforu...e-Island./page2
http://www.rx7club.c...-t-i-sf-850398/
Edited by SFBMX88, 09 July 2012 - 08:10 PM.
#16 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 12:55 PM
August 2009:
Accusump time...I slowly put this together over about a week if I remember correctly.
Made some brackets to upgrade/relocate the power steering cooler:
Mike Bumbecks White 87
While the front end was off I made a "Griffin" radiator....
Relocated the oil filter - now running a larger Ford filter:
Shield for the back of the power steering cooler:
Made an Accusump indicator light:
#17 SFBMX88
SFBMX88
  • 1,543 posts
August 2009 continued:
Flatty love!
Earls oil cooler:
I was always skeptical about socketless fittings, but I am now a believer!  These have never leaked...
Oil Filter adapter(Moroso 23685)
I used the factory gauge and sender to monitor the Accusump pressure:
All done!
Finished my AC delete too.  Duct and plug out of a Mighty Max/D-50:
Edited by SFBMX88, 14 March 2012 - 01:21 PM.
#18 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 01:27 PM
September 2009:
Catalytic converter had a melt down.  This is probably around the time my vacuum advance stopped working....
Pulled my washer tank out to make room for my old MSD 6al.  Made some brackets out of aluminum.
Everything installed with a tiny loaner battery off my Starlet to top it off :)
#19 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 01:42 PM
October 2009:
Pulled the old Walbro 255lph pump out of storage and installed it with new filters(engine bay filter MB504732, in tank filter MB129890, and the pre-pump filter NAPA 3278)
I had to dig around for the install kit that originally came with the pump.  Took those AN fittngs off so I could use the factory fuel pressure hose at the pump.
Fixed some wire ends for the condenser to the pump...
Edited by SFBMX88, 14 March 2012 - 02:04 PM.
#20 SFBMX88
SFBMX88
  • 1,543 posts
Posted 14 March 2012 - 02:07 PM
November 2009:
Old school meet in Santa Clara.  I think this is when the most StarQuests came out.  We had a strong presence in this normally Datsun filled meet.
I saw my old MPI Hurricane manifold living on in a long bed D-50
Also tagged with one or more of these keywords: 2008ls swap, s13 rack, smog legal, flatty, 5 lug, shortened struts, 6 speed, auto to manual
