kf4eok Posted April 19, 2011 Report Share Posted April 19, 2011 (edited) I just wanted to put out a filler to check out the idea of trading my 87 Conquest for a later model Goldwing or a Honda Insight. I might sell it outright.Here is some links to the car. car and another link My TSI linkI have a 1978 Chrysler Conquest that I am thinking about trading for a later model Goldwing or for a Honda Insight. I am just testing the waters to see what might be out there. This car has been fully restored from the frame up, other than paint. The car has no rust or filler at all on the body Here is a link to some pictures of the car http://handymandanon...si-gallery.html Here is some links to some write up of the work that I have done to the car on the forums http://thestarquestclub.com/forums/t5/ http://www.starquest...howtopic=105688 Here is a list of some parts that I have installed on the car to date: Engine: MegaSquirt II Running Sequential Injection and CNP Setup with Wideband EGO and Boost Controll New Crankshaft New Wiesco Forged Pistons New Oil Pump New Adjustable Cam Gear New Timing Kit Recondition Rods Garrett Turbo Rebuilt / Customized at Mikes Turbo http://www.miketurboinc.com/index.html compressor wheel Dia. exducer is 76 mm inducer is 57.7 mm trim is 52 A/R is .50 turbine wheel Dia. exducer is 64.3 inducer is 73.3 trim is 68 A/R is .63 CRYO2 Intercooler. 24” Wide X 10” Tall X 3.5” Thick. With 3” inlet and outlets. With spray bar and Steel Braided line Tube Exhaust Manifold SS MK1 VR SENSOR BRACKET KIT MOOKEEH MK1 CRANK PULLEY WITH EDIS TRIGGER WHEEL ST Performance Fuel Pressure Regulator ST Performance Fuel Filter 4 New Cooling Fans A Large Oil Cooler with SS Braided Lines with AN Fittings New 100 AMP Alternator LS2 Yukon / Corvette Coils (4 of them) Griffin custom made Radiator. It has two 1.5 inch flues which makes it 3 inches thick. Custom made Multiport Intake Manifold with a 75 mm Throttle Body from a 32 valve Northstar engine, Powder Coated Four Delphi FJ10455 75lb Injectors with new connectors Custom made Cam Angle Sensor (CAS) ARP Head Studs ARP Rod Bolts New Fuel Filter Schneider 280F-14 U-FW Solid Follower Camshaft with new springs to match New NON JET Valve Cylinder Head From Engine Machine Service (Dads) New External 38mm Wastegate New Blow Off Valve 2.5 Inch Exhaust - No Converters Custom Hardpipes Balance Shaft Eliminator Powder Coated Valve Cover New A/C receiver dryer and also a new expansion valve. I have replaced all the o-rings with new ones. New Walbro 255 LPH fuel pump New Silicone Heater Hoses Drivetrain/Suspension: 5 Speed Manual Transmission 6 Bolt Axels and LSD New CV- Joints Boots New Wheel Bearings and Seals on ALL 4 Wheels New Front and Rear Struts New Bellows and Bumpers All New Eibach Progressive Springs Suspension Technqiues Front and Rear Sway Bar New Polyurethane Sway Bar Bushings New Polyurethane Endlink Bushings Master Polyurethane Bushing Kit MK1 STARION FRONT AND REAR ADJUSTABLE PILLOW BALL CAMBER PLATES New Findaza Flywheel and puck Clutch and pilot bearing and release bearing New Clutch Master Cylinder New Clutch Slave Cylinder New Brake Master Cylinder Rebuilt all 4 Wheel Calipers Slotted Front and Rear Rotors Steel Braided Brake Lines ABS Delete New U-Joints New Goodyear's Fuel Injection line from the gas tank to the engine Interior: Factory Radio New rear Speakers New stepper boost gage New fuel pressure gageNew Innovative EGO Wideband Gauge and Sensor Stock Radio Trunk Mounted Battery Rebuilt Wiper Motor and linkage and transmission Exterior:Polished Wheels All New Tires 89 One Piece Airdam Gas tank completely reconditioned and painted Thanks for looking, Daniel 904-234-3470daniel@thestarquestclub.com I am also looking for parts for building a total elect car, such as motor and controller.daniel@thestarquestclub.com Edited April 19, 2011 by kf4eok Quote Link to comment Share on other sites More sharing options...
QuestFan Posted April 19, 2011 Report Share Posted April 19, 2011 Too bad you are not closer to Texas, there are at least 4 used goldwings for sale at our shop. Bargers Allsports Quote Link to comment Share on other sites More sharing options...
kf4eok Posted April 19, 2011 Author Report Share Posted April 19, 2011 Too bad you are not closer to Texas, there are at least 4 used goldwings for sale at our shop. Bargers Allsports I understand that. Right time wrong place, that is the story of my life. Quote Link to comment Share on other sites More sharing options...
