FS Va: 2004 Aspen White Subaru Impreza Wrx STi - $12,000
conquezzy
http://richmond.craigslist.org/cto/1705634712.html
Up for sale is a 2004 Aspen White Subaru Impreza Wrx STi. The car currently has 110,000 miles and runs strong. I'm the third owner of the car which I purchased when it had 43,000 miles for 27,000 out the door in 2006. The miles I put on the car are 90 percent highway miles since I use to commute 125 miles one way four days a week to work. The car had the 105k service performed by Pence Subaru which was "timing belt, valve adjustment". Also had them replace the clutch and flywheel with a Act HD Clutch and a Act Streetlite Flywheel. I just installed four new tires in Feb 2010 and replaced the alternator in 2009 with a new one. The car runs great and has very few minor dings. The car has been modified with the following parts and has reported 290 wheel horsepower and 320 wheel torque on the dyno. I don't street race, run at the drag strip or auto-x the car. It served only as my daily driver, but due to personal reasons I need to get rid of it.
Oil gets changed every 3,000 miles with Rotella T6 5w40 Full Synthetic with a Amsoil AE0-13 Oil Filter. The factory turbo was replaced with a turbo from a 2007 STi which is called a VF-43. The VF-43 flows the same as the factory VF-39 but isn't prone to cracking around the wastegate. Radiator was replaced last month with a factory replacement! I currently owe 6595 on the car and that amount will be deducted from the sell price to payoff the car. The Cabin Hvac Air Filter was also replaced a few weeks ago!
***Will trade for cash and a 87-89 Chrysler Conquest or a 87-89 Mitsubishi Starion!***
Power Modifications:
Aps 65mm Cold Air Intake with Fender Block Off Plug
Rare Wbr Performance Front Mount Intercooler
Gruppe-S V2 Coated Unequal Length Header
Invidia V3 Catless Downpipe
SPT CatBack
Cobb V1 Access Port with Friends Agile Pro Tuned Dyno Map
One Step Colder NGK Iridium Spark Plugs
Engine Accessories:
GrimmSpeed Air/Oil Separator
Amsoil EAO13 Oil Filter
Mfactory Subaru Magnetic Oil Pan Drain Plug
SunAuto Hyper Force Ignition Add-On
Circle Earth Ground Wires
Kartboy Battery Tie Down
NRG Polished Hood Dampers w/ SS hardware
Legacy 110-Amp Alternator
Aps After Maf Tube
Drivetrain Modifications:
Act Heavy Duty Clutch
Mach V Steel Clutch Line
Cusco Engine & Transmission Mounts
Turn In Concepts Transmission Crossmember Bushings
Turn In Concepts Rear Differential Race Bushings
Turn In Concepts Outrigger Race Bushings
Kartboy Pitch Stop
Whiteline Rear Sub-Frame Lock Bolts
Torque Solutions Billet Aluminum Drive Shaft Bushings
Suspension Modifications:
Racecomp Engineering Super Sport Street/Track Springs w/RaceComp Front Bump Stops
Pro-drive Rear Bump Stops
Whiteline Adjustable Rear Strut Bar
Wheels/Tires Modifications:
Stock Gold BBS Wheels
Maxxis MA-V1 Tires
Mcgard Lugs
Hawk HPS Pads
Interior/Exterior Modifications:
Wrx Fog Lights
2006 Headliner ABC Pillars and Black Carpet
2005 STi Windshield
2004 Black WRX Front and Rear Seats
Killer B Motorsport Black Cylinder Shift Knob
Mach V Tow Decal
Prosport Dead Pedal
Primitive 3/16th Rally Skid Plate
After Maf Hose and Radiator were changed after this pic was taken!
http://hphotos-snc3.fbcdn.net/hs518.snc3/27174_375986064908_501259908_3439083_2171490_n.jpg
http://hphotos-snc3.fbcdn.net/hs215.snc3/22239_277458829908_501259908_3100899_3256067_n.jpg
Some other parts were added after this dyno run! Needs another tune to get more power from the added parts!
http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs215.snc3/22239_277493034908_501259908_3101127_1512152_n.jpg
Edited by conquezzy
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
