Boosted_One Posted March 22, 2002 Report Share Posted March 22, 2002 ORIGINAL POST CREATED BY MIKE CEBULA ----------------------------------------------------- The relay for the entire fuel injection system is called the "ECI control relay" and it's located above the ECU inside the car. Â If you remove the glove box, it'll be attached to the A pillar extension. Â There is no fuse for the fuel pump; the whole system is protected by the "ECI" fusible link. Â This link is in the engine bay between the battery and ignition coil. Â Look for "ECI" on the box. The test lead Tim mentioned is a black+red wire on 87s and black+white wire on 88s (I don't about other model years) with a protective cap on the connector; it should be a 1-lead connector hanging between your air filter box and the fender. Â When the ignition key is in START, you should have +12volts on this wire if the pump is getting power. mike c. Link to comment Share on other sites More sharing options...
The_MATRIX Posted January 6, 2005 Report Share Posted January 6, 2005 ttt Link to comment Share on other sites More sharing options...
