iGSR_VR Posted January 12, 2013 Report Share Posted January 12, 2013 I was wondering if any one has done the GM AUto Matic Transmission swap I have a copule questions? Link to comment Share on other sites More sharing options...
Ironside Posted January 12, 2013 Report Share Posted January 12, 2013 Pm Bill Hitchner (sp), He makes adaptor plates for GM trannys.4cylinderfury runs a turbo 350 I think, I've always thought a 700r would be a good tranny for our cars.I'm just worried about the size differance. Link to comment Share on other sites More sharing options...
Ironside Posted January 13, 2013 Report Share Posted January 13, 2013 http://www.starquestclub.com/forum/index.php?showtopic=134875&hl= Link to comment Share on other sites More sharing options...
iGSR_VR Posted January 13, 2013 Author Report Share Posted January 13, 2013 Thanks a Million just send him a PM Link to comment Share on other sites More sharing options...
Bill Hincher Posted January 26, 2013 Report Share Posted January 26, 2013 never did get your PM >;o) Link to comment Share on other sites More sharing options...
KIDMEN Posted May 30, 2013 Report Share Posted May 30, 2013 i am interested in this cause i have an auto and i am not going to get rid of my quest because its an auto it is just as fun and i love this car Link to comment Share on other sites More sharing options...
Bill Hincher Posted May 30, 2013 Report Share Posted May 30, 2013 This is the GM powerglide/ TH 350/ 400 adapter worksheet, its been in production many years the plate will share one design, the difference will be in how its drilled, I been bouncing around about the thickness, also i tried some new ideas on the starter location. I finally settled on the starter location and thickness is still up to the coupler I want to use, the problem I am wrestling with is the crankshaft bolts. the original M/T crankshaft bolts have a bigger head for more clamping force but they are designed to work with a flywheel 10mm thick, the auto trans bolts are designed to work with a flywheel 3mm thick, If I swap the auto trans bolts for the M/T bolts I will gain in strength but the fingers i used to locate the center of the torque converter will be much thinner, however the thicker coupler will force the trans to be mounted an extra 1/4 back with the adaptor plate so i been bouncing back and forth the original auto trans flex plate was 3 mm thick, my first couplers were 7 mm thick under the bolt headhttp://www.billsautofab.com/images/updateGM16.jpg http://www.billsautofab.com/images/updateGM17.jpghttp://www.billsautofab.com/images/updateGM22.jpg I keep working out details in the new plate, I want it strong but lighthttp://www.billsautofab.com/images/updateGM1.jpg http://www.billsautofab.com/images/updateGM3.jpghttp://www.billsautofab.com/images/updateGM4.jpg http://www.billsautofab.com/images/updateGM5.jpg This is my new coupler , it has 10 mm thick flywheel bolt landings and uses the Manual trans boltshttp://www.billsautofab.com/images/updateGM6.jpg The flywheel fits okay but the starter depth will need adjustmenthttp://www.billsautofab.com/images/updateGM8.jpg Link to comment Share on other sites More sharing options...
Bill Hincher Posted May 30, 2013 Report Share Posted May 30, 2013 these are the first heat treated couplershttp://www.billsautofab.com/images/crankshaftcoupler19.jpg http://www.billsautofab.com/images/crankshaftcoupler20.jpg I added some side mounting motor mounts in my latest designs, for guys that wanted a mid platehttp://www.billsautofab.com/images/GMtransadaptor19.jpg http://www.billsautofab.com/images/GMtransadaptor20.jpghttp://www.billsautofab.com/images/GMtransadaptor21.jpg http://www.billsautofab.com/images/GMtransadaptor22.jpghttp://www.billsautofab.com/images/GMtransadaptor23.jpg http://www.billsautofab.com/images/GMtransadaptor24.jpghttp://www.billsautofab.com/images/GMtransadaptor25.jpg http://www.billsautofab.com/images/GMtransadaptor26.jpghttp://www.billsautofab.com/images/GMtransadaptor27.jpg Link to comment Share on other sites More sharing options...
Bill Hincher Posted May 30, 2013 Report Share Posted May 30, 2013 This is the work detail to make the Toyota reduction gear starter to work http://www.billsautofab.com/images/startergear3.jpg http://www.billsautofab.com/images/startergear4.jpghttp://www.billsautofab.com/images/startergear5.jpg http://www.billsautofab.com/images/startergear6.jpghttp://www.billsautofab.com/images/startergear7.jpg http://www.billsautofab.com/images/startergear8.jpghttp://www.billsautofab.com/images/startergear10.jpg http://www.billsautofab.com/images/startergear11.jpg http://www.billsautofab.com/images/startergear12.jpg http://www.billsautofab.com/images/startergear13.jpghttp://www.billsautofab.com/images/startergear14.jpg http://www.billsautofab.com/images/startergear16.jpg I am going to order the 604 from powermaster Link to comment Share on other sites More sharing options...
benja92231 Posted May 30, 2013 Report Share Posted May 30, 2013 Sir you are a master at your craft Link to comment Share on other sites More sharing options...
Starquest87Jimmy Posted October 20, 2013 Report Share Posted October 20, 2013 Can you make a MPI intake for the 4g63? Link to comment Share on other sites More sharing options...
SOTTY Posted October 22, 2013 Report Share Posted October 22, 2013 Sir you are a master at your craftX2 , you never can get enough of a Hincher post/pics . Scotty Link to comment Share on other sites More sharing options...
