StarquestRescue Posted May 18, 2010 Report Share Posted May 18, 2010 http://cgi.ebay.com/ebaymotors/Miller-Tools-PULLER-GEAR-BEARING-MD-998056-A-/110526370599?cmd=ViewItem&pt=Motors_Automotive_Tools&hash=item19bbe29327 I bought one of these a while back for $50. I have not tried it but it looks like it would work. The tools from all those closed dealerships are hitting Ebay. Quote Link to comment Share on other sites More sharing options...
ucw458 Posted May 18, 2010 Report Share Posted May 18, 2010 Not sure if that would work. The ebay part # is MD-998056-A and in the FSM the part # for the puller is MD998020 Quote Link to comment Share on other sites More sharing options...
Metric-man Posted May 20, 2010 Report Share Posted May 20, 2010 Not sure if that would work. The ebay part # is MD-998056-A and in the FSM the part # for the puller is MD998020 They revise the numbers for tools just like parts. Could be the identical tool with a small improvement to the the original design. Although most improvements are also done for manufacturing cost in mind, the original tool is usually superior in performance and function. Some tools are modified from the original design with intent to expand for use in other models. There are updated print publications from the manufacturer like catalogs with technical service bulletins, as well as websites for tool manufacturers that use search engines with parameters for obsolete / updated specialty tool numbers. http://millerspecialtools.spx.com/ http://www.otctools.com/ Quote Link to comment Share on other sites More sharing options...
ucw458 Posted May 21, 2010 Report Share Posted May 21, 2010 They revise the numbers for tools just like parts. Could be the identical tool with a small improvement to the the original design. Although most improvements are also done for manufacturing cost in mind, the original tool is usually superior in performance and function. Some tools are modified from the original design with intent to expand for use in other models. There are updated print publications from the manufacturer like catalogs with technical service bulletins, as well as websites for tool manufacturers that use search engines with parameters for obsolete / updated specialty tool numbers. I understand part #s get updated over time but if you look up the origional part # MD998020 at mitsubishi the part # was never replaced or updated. Quote Link to comment Share on other sites More sharing options...
StarquestRescue Posted May 21, 2010 Author Report Share Posted May 21, 2010 (edited) I will dig mine out and try it some day. I may or may not let you guys know. Few here have the skill to do trans work anyway, and some key 88-89 parts are allready nla. Edited May 21, 2010 by StarquestRescue Quote Link to comment Share on other sites More sharing options...
Metric-man Posted May 22, 2010 Report Share Posted May 22, 2010 (edited) I understand part #s get updated over time but if you look up the origional part # MD998020 at mitsubishi the part # was never replaced or updated.The part number you mention has extension arms that were later offered separately.I believe the part number you have involved the combination of both the puller and extension arms. Edited May 22, 2010 by starion_cult Quote Link to comment Share on other sites More sharing options...
ucw458 Posted May 23, 2010 Report Share Posted May 23, 2010 The part number you mention has extension arms that were later offered separately.I believe the part number you have involved the combination of both the puller and extension arms. The extension arms are part # MD998029-01 and the FSM says Use with MD998020 puller. Quote Link to comment Share on other sites More sharing options...
Metric-man Posted May 23, 2010 Report Share Posted May 23, 2010 The extension arms are part # MD998029-01 and the FSM says Use with MD998020 puller. This is not a threat but, One of these days I will find my specialty tool catalog and let you know the know the correct / updated number . Quote Link to comment Share on other sites More sharing options...
ucw458 Posted May 23, 2010 Report Share Posted May 23, 2010 This is not a threat but, One of these days I will find my specialty tool catalog and let you know the know the correct / updated number . That would be fabulous. But just for reference not all part #s get updated. If you type those #s into an online mitsu parts supplier you will get no updated #s. http://www.oemmitsubishiparts.com/ I've looked up many parts on that site and every so often it will show the origional # and tell me it was updated to a different part #. But when I put in the puller part #s it doesn't list an updated #, just a price. ############## I had to do that. Soo many #s in that last statement. Quote Link to comment Share on other sites More sharing options...
StarquestRescue Posted May 24, 2010 Author Report Share Posted May 24, 2010 (edited) Not sure if that would work. The ebay part # is MD-998056-A and in the FSM the part # for the puller is MD998020What was the problem again? There is also a brand of puller called posi lock that should work if you get the right one. The extensions can be bought new from miller tools reasonable. http://millerspecialtools.spx.com/Detail.aspx?id=1256&gid=18 http://i237.photobucket.com/albums/ff45/StarquestRescue/Transmission/DSC01848.jpg You will need a good snap ring pliers, these are flat on the ends. Expect to damage the snap ring so check availability first or use more patients then i did. Edit, the snap rings come in different sizes. You are to use the thickest one that fits back in iirc. Best to take time to get it off with out damaging it.http://i237.photobucket.com/albums/ff45/StarquestRescue/Transmission/DSC01849.jpg Lock the trans in two gears so the gears will not spin.http://i237.photobucket.com/albums/ff45/StarquestRescue/Transmission/DSC01850.jpg http://i237.photobucket.com/albums/ff45/StarquestRescue/Transmission/DSC01851.jpg Edited May 24, 2010 by StarquestRescue Quote Link to comment Share on other sites More sharing options...
ucw458 Posted May 24, 2010 Report Share Posted May 24, 2010 Well I never said it wouldn't work. All I said was I wasn't sure it would because the part # was different. FYI, I'm the one who bought that puller. I have a few spare trans that need work so I'll find out soon enough. Quote Link to comment Share on other sites More sharing options...
