TB Rebuild Kit/Rebuilding the TB
3 replies to this topic
#1 KO
KO
  • 2,757 posts
Posted 29 April 2002 - 09:29 PM
Posted by MoMagnum, nice work!
http://personalpages.tds.net/~momagnum/
Insta=extexascoach
Posted Image Posted Image
89 TSi 14G, 2.5"Ex,21lb.Flyw, Sht.Shift, SS Hoses,1G MAS/K&N,
125psi F.Pump, Type-H BOV /H-Pipes, 9" Rears, ST's, KYB's.
2008 Toyota Tundra Crew Cab
2014 Silverado Texas Edition
2016 Escalade Platinum Edition
#2 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 04 February 2004 - 03:46 AM
Yep, 1529...Since this is already in the FAQ's, i'll post info...
It came with a "Throttle Body-service instruction worksheet" TO REPAIR: Chrysler T.B.I. (2 electronic controlled injectors)
It has an exploded view of the whole SQ Throttle body. The kit contains:
Upper injector O-rings(2)
Seal for injector**special cut-out**(2)
Seal for injector-lower**Flat side faces up**(2)
O-ring for the "pulsator damper"(1)
Diaphragm, pulsation damper(1)
O-ring for the FPR**These are for the three little nipples that go into the TB**(3)
Seal ring***LEMON SHAPED GASKET***(1)
Seal ring**regular gasket for the base of the TB(below the lemon shaped one)**(1)
O-ring for fuel inlet line(1)
Trust me, it's everything you'll need and then some. The kit also comes with a tiny ball bearing and a little C-clip, it's not used on our TB.
After I recieved my original order and saw how complete it was, I ordered two more kits the next day. I keep one in my car at all times, not to mention some other things....
John
#3 JustPaus_88TSi
JustPaus_88TSi
  • 13,960 posts
Posted 10 February 2004 - 03:17 PM
Are you talking about the lemon shaped gasket?  If so, how do you know it's leaking? The reason I ask this, is because that gasket is an internal one. Do you see some kind of fluid on the outside of the TB?
John
#4 Komeuppance
Komeuppance
    Amused.
  • 13,590 posts
Posted 13 July 2008 - 11:42 PM
Shaft seals can be had easily by taking your current seals to an industrial supply center.  They are basic seals that are cheap.
-Robert
