qadir03
Everything posted by qadir03
  1. I am running the TBI injectors, I can't tell if they are the secondary or the primary. Do you guys have a way of finding out by part number? These are the list of the injectos I have with part number and where I got them from. Injectors have been flow tested so all the flow rates are accurate. MIRAGE: L85-2 L25-3 65.5 POUND PER HOUR 688CC@3BAR TREDIA: B59-2 B59-2 3BAR=76ML 40PSI=72ML 57.9 POUND PER HOUR 608CC@40PSI 87 STARION: J57-3 J57-3 3BAR=122ML 40PSI=116ML 85.3 POUND PER HOUR 896CC@40PSI 85 Mirage B55-3 40PSI=70ML 43 POUND PER HOUR 452CC@40PSI I need to post another log. I had the TPS threshold set at 30V, so that is why no accel enrich is kickin in. Like you said about puddles of fuel, that is what I was thinking of. I think if i set the overrun to cut fuel below 90kpa, tps at 0% and above 2000 rpm that might help.
  2. I am using 2 608cc injectors set at alternating. I will mess with tuning it more this week. Does anyone here have MegaSquirt with their TBI. Since this is a TBI setup, I believe that the injectors are way too far from the combustion chamber to react fast enough to stop stop feeding fuel when the change in manifold air pressure is so high. That might be causing the rich mixtures after getting of the throttle under boost. What kind of injectors are you using and are you using a wideband?
  3. My tps is calibrated correctly, I almost never go above 50% to get the car going. Are you running the TBI or are you MPI. My map is as good as it gets. I've been running MS for over a yr now. I just haven't been able to get the accel as smooth as posible as I can. As for deaccell do you rich out when you get off boost?
  4. I have been trying to tune the accel enrich for a while now and can't seam to get it to work properly. Also what kind of deaccel setting are you guys using. Whenever I get off the throttle after being on boost a cloud of black smoke apears. I have overun kick on and deaccel set to 0%. http://students.washington.edu/qadirz/MegaSquirt/DATALOG%20AIR%20TEMP%20RISE.JPG Here is my datalog: Wideband set at 0V=10AFR 5V=20AFR http://students.washington.edu/qadirz/Mega...00508071921.xls Here is my MSQ: using MegaSquirt2.25b442 http://students.washington.edu/qadirz/Mega...00508072007.msq
  5. I am using MegaSquirt on my TBI set-up. It works great and has great data-logging features. http://students.washington.edu/qadirz/MegaSquirt Zia
  6. Hi, I am using the TBI injection system on my Tercel. I also used MegaSquirt to control the fuel curve. Here are some pics: http://students.washington.edu/qadirz/MegaSquirt/ I plan on going MPI soon, I would recommend using MegaSquirt , due to cost and functionability. zia
