dattson510
Everything posted by dattson510
  1. Reduced the price. $1000. Here's the new ad craigslist Forgot to mention that it's a manual.
  2. Lost my job and I need to get rid of some projects. Car is in Portland OR. craigslist
  3. The tank has never been run dry. I thought that it might have before I noticed the missing ground on the KB. I know if it's going to start when I see the in line fuel pressure gauge reading 40psi. It is either 40 or 0 no in between. When i have the pressure it starts right up and I've driven for about 25 min or so playing with the throttle to see if there is any lag or if it will quit. No problems. It runs strong and smooth. To me it seems like the pump is OK, but sometimes it's not getting the signal to turn on. If the ECU has been F'd up or the relay, is there a way to test for proper functions. Did some research and a new KB is $300-500? really? Can the KB be replaced with an MSD or something less expensive?
  4. Is there a way to test the ECU to see if it's functioning properly?
  5. i went back to get the car and when i opened the hood I noticed that the knock box wasn't grounded. Threw a bolt in there tuned the key and instantly had fuel pressure. Got a jump and was off. The problem is still there. Sometimes it fires right up and runs great. Other times it just cranks. I check under the hood and the fuel pressure is 0. The tach does move when I crank it. Fuel pump going bad? Do I have to drop the tank to replace? Thanks
  6. Hey Guys, It's been a while since I've owned a StarQuest but I bought an 87 yesterday. I just couldn't stay away.... Anyway, I drive it about two blocks and stop to get some celebratory lunch. When I get back in I crank it and it fires for a second then dies. I knew it was very low on gas so i figured I had ran out. picked up the gas can and put two gallons in it. Cranked it and still wouldn't start. After a while I popped the hood, turned the key to on and there is no fuel pressure showing on the in line gauge. Also can't here the pump trying to prime. Could it be my bad luck and the knock box went out? If the KB is out will the pump still turn on? Any thoughts? I'm having it towed to the house in a bit so I can start working on it. Thanks
  7. The pop up lights are just one more thing to go wrong with the car. I was thinking of doing this mod as soon as I bought my quest. If you got a Playstation 2, check out the game Tokyo Extreme Racer. There is a Starquest on there and you can do all kinds of body mods including flush mount headlights. Pretty cool! Ryan
