Hi yall, I hope someone can point out some areas to look at. Basically sent to machine shop. They supposedly tested everthing milled where needed etc. Got back a short block with Wiseco forged pistons, installed the balance shaft elimination kit and plugged the gallery. On the head, minor porting and replaced eliminated the jet valves.
Now.. motor starts and sounds great but instant Milkshake and a lot. Like a missing plug or incorrect hose hookup. Have gone thru and had a buddy that works as a mechanic come over to confirm. We can't isolate the issue.
Basically no mix unless motor is funning. Coolant system. Holds pressure no leaks. Compression and leak down rule out not a head gasket.
So basically, I'm down to something to do with possibly the front cover? We both came to conclusion motor will have to come back out and be torn down again and I'm oh so bothered. Haha while digging into it. Anything that I need to be looking for? Anyone else have a similar issue right after rebuild? Any help or suggestions greatly appreciated. We just can't find any leaks with air. Its only missing when running. Not under pressure so it's all internal whatever the issue is.
