Everything posted by 89fiji
This is sweet, can't wait to see more.
So now that its a bit warmer out, I've had a little bit of time to check out the car again. Got a little 194 bulb and two wires hooked up to the primary and it appears to just turn the bulb on as opposed to pulsing. Addtionally I can't really keep the car running now. The bulb brightens and dims as the car goes up and down in rpm. Not sure what this is indicating.
Hey guys, quick question, possibly dumb noob mistake . Has anyone ever hooked up the battery cables to the incorrect terminals, or hooked up a charger to the battery with the cables switched. If so what would happen? Fry the ecu? or something else? I'm thinking I may have absentmindedly done this at one point and fried something. Would be the dumbest mistake I've made yet, but if these symptoms I'm seeing are indicative of a fried ecu/eci system then it would explain a lot. Thanks
87 starion and 87 quest....... 1000 for both
89fiji replied to 86silverstarion's topic in Cars for sale
Would you be willing to part with just the 83 Hood? -
Is anything still available? -
So went through some other things in addition to what's listed above. I'm still not 100% on fuel pressure, dont have a gauge, but it really does look like it is getting plenty of fuel. Can hold my thumb on the line and it pushes hard. The return line is also clear. All the filters are clean and flowing well. Pulled off injectors and flowed them and checked for leaks, and they seem great as well. Checked continuity through the wires of the cts to the ecu and there is little to no resistance. Cts is brand new and ohms out properly. Timing seems perfect. Plugs are new, great spark. Set tps and checked isc. Still cannot figure out why the car gets warm and just dies, then is very difficult to restart and keep running. Not sure where else to go from here or what to check. Also spent about 3 hours last night reading through the fuel injection section of the FSM, and checking any post on the forum here that had anything to do with a non starting issue or bad idle problem. Any other ideas fellers? Thanks.
Hey guys, have been searching through the forum quite a bit for similar issues and have replaced some parts and checked some things that similar posts have provided answers to, however am still very stumped. I'll try to be as descriptive as possible. Car is an 89 conquest, manual, has some mods, hard pipes and bigger intercooler, 2 1/2 inch exhaust piping and hks muffler. Was running about 17psi before this issue showed up. The turbo seems like it may be dying, but is not currently the issue I'm facing. Real issue at the moment is car dies after warming up. I have replaced coolant temperature sensor. Compression on all cylinders are around 110-120. Spark seems very good and timing is set. New fuel pump, filter is nice and clean as well. The car has what appears to be good fuel pressure all the way up to the injectors, but after the car warms up it sputters and eventually dies. I then pull off the ovcp and visually inspect the injectors through the throttle body and while cranking the car over (cranks very well), there seems to be no fuel coming out. Thanks for any advice in advance, great forum so far, hopefully after figuring this issue out I can contribute my findings to the information already here. it starts and runs when cold once it runs and starts to warm up it dies. as soon as the ECU temp sensor cools the process repeats. tried new ECU Temp Sensor same results.
Should I ask questions here? I've done quite a bit of searching, and am starting to feel like none of these cars have the same issues as any of the others.
