Hey Guys I have my 1991 Mitsubishi Eclipse GSX I'll take $3975.00 firm for it. I just need it gone, wish I had the room for it or a need for it. Its a 5spd, with 87,731 miles as of right now but I drive it once in awhile to get the fluids moving, it's Green exterior, Tan interior, pop up sunroof, factory cd and cassette player, leather seats, ABS, power steering, a/c has been retrofitted to r134a all you need to finish is the a/c belt tensioner and a charge of r134a. Car drives great just has a belt squeak after I took off the old a/c belt, don't know if I put the alternator belt on alittle tight or loose, squeak kind of goes away while sitting at idle. Car comes with but needs to put on, a/c belt, timing belt, balancing shaft belt, water pump, and idler pullies. Replaced the front brakes, valve cover gasket, oil pan gasket, clutch (with act 2100), condenser, dryer, updated clutch pedal assembly, rebuilt original transmission by Jack's Transmission (1,000 miles on it). Pretty much everything else is stock. Car has tow hitch and wiring harness for it, I never towed with it, I believe the original owner just got it with every option you can with it. Other than the belt squeak, and a/c system to be finished, the antenna mast is broken and the drivers front seat is ripped and headliner is also ripped but both can be reupholstered or replaced, there is a rust hole on the passenger front fender, and a dent on the drivers front fender, normal sun fading and both body side mouldings have fallen off but I've seen other eclipses with them completely off and they look better. Please email for more info at robert.aldape902@gmail.com Pictures can be seen here on my autotrader add and if you go down a little bit and to the side theres a carfax to comfirm the mileage. http://www.autotrade...ingId=323249205
