nekkidlad
About nekkidlad
- Birthday 01/04/1986
Farmington Hills, MI
48335
1988
Auto
Rusted
nekkidlad's Achievements
ok so finally i got around to doing a 87-89 tps/isc reset(for any of you who have read my other thread..) on my dad's 88... i tried to follow the top procedure on this thread... http://www.starquestclub.com/forum/index.php?showtopic=28069&view=&hl one thing tho...i can't hear the "zip" of the motor at all...i would guess by the lack of sound it's just not working can anybody let me know where i can find a new/refurbished/used one?..i tried usiong the search thing but i get like 200 unrelater results because "motor" matches something else(yes i used the + already, that made less related matches) so then i tried following the "reduced" instructions on the 2nd post...i found that the wires for the isc and mps are described but kind of confusingly and had to spend like 30 minutes finding what terminal 2 and 3 were....so im not 100% sure im doing things correctly....and i could never find the .9 volts...i did however set the tps to .47v because it kept moving on me everytime i tightened it...it always either overshot or undershot...couldnt get it quite exactly at .5v but .478v was the closest i got(after tight)...(plus i figured id have to reset it again later anyway)
^pm'd
already did the fuel filter in the engine bay.... unless theres another one wich im sure there isnt...(besides the in-tank screens ive read about) i figured theres gotta be a wire or a hose worn somewhere...but i wannna do that tps/isc reset first...but havent been able to...and im kinda stuck at the "need to do reset first and go from there" spot...
got the car back outside of work...the guy thinks its the egr valve...but he also thought it jumped time and it had a vacuum leak when he was proven wrong...wich is still wrong...and the egr is not it either... anybody need new a egr valve?...got a brand new one inside the car...haha.. gonna try this week to get a meter...maybe this week ill shoot u^ a pm to possibly work on it this week if ur available..?
maybe sometime in the next 2 weeks...this last week my dad took the car w/ one of his friends because he "knew for sure what's wrong, and would take him a day or 2 to fix it".....1.5 weeks later he still has no clue whats wrong... checked everything i checked came up with the same conclusions...xept the maf is already rebuilt and the o2 sensor is already new...and theres no vac leaks and so he doesnt know what to do to fix it...he was for sure it jumped time..but now says for sure it didnt...(even tho i told him like 3 weeks ago it didnt) they SHOULD be bringin it back sometime this or next week..(possibly on a flatbed..) ps...a few weeks ago i saw a bright blue conquest drive by my work(gd river av./10mile and haggerty) while i was on a test drive in a customer's car..i wanted to take off and chase it down so bad see if i could get any possible help...but the customer was waiting and it was just about closing time...so i was unable to do so...(not to mention it'd be somewhat awkward to chase some1 down like that..)
already have it bookmarked but thanks for the link to the manual. also have printed instructions from one of the threads in here for the tps/isc reset, for whenever i can find a meter.. i know mafs seldom go bad but i figured its over 20 years old anyway...probably a good idea regardless...(even tho it didint fix anything...)
i had the mass airflow sensor sent out to be rebuilt by a company...(i tried to buy a new one but they didint stock it anymore they just sent me the instructions and reduced the price to rebuild intead of buying a new one) got it back last week all freshly rebuilt....same problem..(obviously i spent $150 on nothing) also replaced the o2 sensor... did a hard reset..(well it sat outside without a battery in it while it charged for a week and a half) still havent done the tps/isc reset..havent been able to go out n find an analog volt meter.. ir runs ok if i leave the maf sensor disconnected, but it idles high and it GUZZLES gas...took about 3 hrs total of idling over a 2 days for it to use 2 gallons of gas.. any thoughts?
^^I know its not very safe to drive the car int hat condition and its not the best idea to brake torque the heck out of it, but its the only things I can do at the moment...no, I'm not trying to kill anybody, I made sure to go down an empty street with no cars, and that I know theres very few people...its an industrial drive.. I dont have the time to work on it much more...at least untill it gets warmer out..I dont feel like standing outside in the cold and wind working on the car...all I'm trying to do with the car is make it my dad's halfway decently reliable daily driver... After about 3 months of having the car sit outside work, I figured out a guy I work with every day used to be a conquest/starion tuner back in the day..(of course it's the only guy I didnt ask about the car, I asked the other 4 guys I work with tho...he's kind of a d-bag, but he knows his stuff) Also after I get the car running "normally", I'm getting all new pads, rotors, brake fluid, coolant, and tires...(hopefully it doesn't need calipers). He doesnt have much money to fix the car...(I hope this thing is not going to be a pit...being an '88, and some parts being so hard to find and get, etc...)
UPDATE: finally got a chance to work on it.. I found an electrical connector that fits the injectors in the utility room at work..(we have random scrap harnesses for scavanging connectors and wires in there). I spliced the connector in(soldered), and cleaned the injector side of the connector some and plugged it in, put gas in it and started it up. It ran fine for a while, doesnt die if you brake torque it past 0psi boost...(went up past 7psi on the OE gauge)... It still rolls the idle after heating up. Got it to drive around the block got to around 30mph...(I didnt feel very safe going that fast..or faster since the brakes are severely rusted and 3 of the tires have grooves carved into the sidewall from running flat from previous to our ownership) Anyway when it rolls the idle it goes from about 1500-2500rpm. While you're driving it almost feels like the engine stalls out, but then it feels like you just floored it abut a second later if you keep your foot down. I still have to do that tps/isc reset...havent had a chance yet to do that...or a hard reset...
no...no....and no.... ive been very busy...at work, planning my wedding, taking up my extra time getting money on the side working on other people's at work's car...among other things.. havent really had any time for the conquest in like 2 months...(xept for last week when i found the port for that one hose and the injector corrosion and the trouble code lights...wich took all of about 15 mins..)(and i left work about half hour late because i was outside in the parking lot "working on" the car...) as soon as i get a chance ill put up an update... for now the conquest stays at work hanging out in the back lot...(surrounded by jaguars...hope it doesnt get eaten)...since i live in an apartment and i cant work on it there...plus i have no tools there...
^^codes are listed on post #11..
single port under tyhe row of 3 at the TB? UPDATE: found the port..plugged the hose in unable to run acr at moment still out of fuel..have to get time to get gas and put it in to see how much better it runs now(hopefully better)
had a minute to work on the car, i looked at that hose it comes all the way across from the other side of the engine compartment and it's attached to 2 black cylinders with like 3 diferent t's.. i did not see anything unplugged at the TB...when i get a chance to worn on it again ill take a picture or 2 and see if any1 can let me know exactly what it is and where it goes.. i tried the led thing to get codes and i got the light to flash 1-o2 sensor, 4-DONT KNOW, 5-TPS and 6-ISC...i was key on, engine off..(out of fuel at the moment) (PS: if anyone knows what 4 means...let me know...my list of codes has it as N/A..) also i checked the 2 connectors at the injectors one had a metal clip that locks it into place the other one has it missing...i didnit have anything to help get the clip off so i checked the one w/out and there was a bit of crud in there...sometime when i get another chance ill see if i can clean it up a bit..for now i just plugged it back in..after i clean up the connector at the injector, and hopefully do the tps/isc reset ill to disconnect the battery and hopefully have the car reset and see what happens...
i printed out the procedure for the isc/tps reset and will do it when i get the chance..ill also check the conectors...make sure theres no corrosion or something of the sort.. also i found what looks like a vacuum line disconnected right by the master cylinder...it comes from the other side of the engine compartment...theres no vacuum at it and i cant find what it would connect to on the drivers side of the engine compartment...and i can't see where its coming from...(if its even plugged into anything at all...) and no it's not the washer nozzle hose...i thought it was that since there was no vacuum and the hose was about the same size as a washer hose ussually is
