adookie02
Everything posted by adookie02
ok guys 2years into it got her done and now i gotta say goodbye and let her go i need the money daughters sick i need the money for doctors... its an 87 quest 5spd rio red stock motor 1st gen bov brand new upgraded alt and fuel pump. greddy turbo timer. i fill up at exxon on super she boosts at 9lbs aftermarket boost guageac heat power windows everything works just gotta put the belt on for the ac left it off when i changed the belts.. polished/painted rims not clear coated in case of color change 161,xxx on chassis 81,000 on motor from another quest.... 2500 askkin message me for more or email @ adookie02@aol.com located in newjersey
its an 87 quest and noi couldnt find anything for that year.... my state requires every 2 years for inspection.... thought this august passed a new law stating on emmission will be overviewed but again i wanna remove everything i dont need except abs kinda need that in the winter
ok guys i need some help from the club. i wanna clean up my engine bay BUT unfortunately i have emmissions in my state (it blows)... so i would like to know what i can remove while still bein able to pass emmissions. its an 87 quest.. i need proper locations for boost guage bov vac advance and all that good stuff. i went through the faq's but diagrams are for 86 and 89 idk which one would apply to me... so hopefully someone who has done eliminations can help a fellow quester out.. THANKS IN ADVANCE
can anyone tell me why i get exhaust fumes in the car as i get on the car.... i dont get the fumes when i drive normal only when im gettin on the car aka w.o.t
ok indiana.. i did what you said and im gettin 8lbs now was barely gettin 7 now 8 on the money... i dont know if i did something wrong but i doubt it i did what u said.. a hose from the ovcp to the tee then from the tee to the actuator and the other port left open
ok so i dont have to get a boost controller? just a 1/16 tee put it in the line and another line from that to the actuator and leave the other open end open?
ok check it out i got an 87 quest with an 88-89 ecu 1st gen bov upgraded fuel pump aftermarket boost guage ( most of the basics needed) now other than that its stock so my question is how much boost can i push on my 12a.. i believe its a 12a iths the stock 87 turbo. now my by buddy said i can change the waste gate to an 88-89 waste gate and ill get 10 psi that way.. idk.. so im turnin to the club.. educate me please
anyone got a link for things that ca be eliminated under the hood
ok well i checked the actuator arm thats all good i tightned every singlge hose that has a clamp on it and it seems to boost a 6-7.. wats normal boost for an 87 stock..
thanks indi will try and get back to u
how can i test to see if the actuator is bad?
yea a pair of vice grips on the actual arm towards the actuator without that i cant boost
ok i get wat ur saying but i also wanted to do it different than everyone else..
ok now i changed my vac advance to a workin 1 installed an aftermarket boost guage.. now my problem is that it wont boost. i mean it boosts but very low like 3 or 4 lbs and that cause i got a pair of vice grips on the acuator arm
2nd pic
ok i finally got started on my rims. so wat o u guys think
