HI All well its time to sell my 1987 conquest tsi. Red with blk leather in excellent condition! 5 spd, shifts perfect! race built motor 11k miles ago. I use this car as my daily driver and never any issues! here is a list of what was done to the car! i have reciepts for everythin!! Just the turbo kit was $1100.00 !! I also have original owners manual, 3 keys, repair manuals, chiltons manual, extra tsi emblems, etc....will get pics tonight......has 3 piece damaged front air dam, i have a new 1 piece from tep, i can have it painted and put on, or you can have it new in white , up to buyer!
4 New Hypereutectic Pistons. ( .040 over )
Total-Seal Piston Rings
Balance Shaft Eliminator kit
Timing Component Kit for use with balance eliminator
Clevite 77 rod and main bearings
Head gasket set
Lower end gasket set
New Head bolts
Heavy Duty Valve spring set
TEP Camshaft Upgrade
New water pump
Race ported and polished head (Jet valve elimination)
New 19C Race Turbo
New ported Max Flow cast iron exhaust manifold
New Steel braided oil feed line
New Steel braided clutch line
New Steel braided brake lines
Cross drilled and slotted rotors
Ceramic brake pads
Mandrel bent racing downpipe to replace stock pre-cat
3 Wire 02 Sensor
TEP Hard pike kit
Over the Valve Cover Pipe with TurboXS Racing Blow Off Valve.
HALMETER AF/30 Air fuel ratio indicator.
TurboXS Dual stage boost controller
Lightened flywheel
Heavy Duty Street Clutch
Short throw Shifter kit
TEPs Bosch Replacement 350 HP fuel pump
89 ECU
Dual Coilover lowering springs
KYB GR-2 Struts
Under drive Pulley
High volume electric cooling fans (with TEP relay kit)
There are a couple small areas of rust bubbles above lr wheel well, but can easily be fixed!
I just had both frame rails repaired with all new steel(welded in)!
Any questions plz call dan at 603-783-1390
thanks for looking!!
