See, I did the T-Racing mod where you put the T fitting it the waste gate vacuum line and that made me run at 14 psi, I then regapped the sparkplugs to .032 and advanced the timing to 9* BTDC. I also did not have time yesterday to list some of the mods I do have like ported exhaust manifold, intake manifold is also ported. High flow fuel filter, gutted pre-cat. See, I have seen turbo cars run compression ratios up to 11.0:1 with engine management. The conquest factory compression ratio is 7:1 and the Montero has a compression ratio of 8.7:1 but in reality the true compression ratio for my setup is around 8.55:1 with the porting and polishing and the valve grind. Now, engine damage occurs only when the temperature in the combustion chambers is to great and this causes the air/fuel mixture to ignite prematurely or burn a hole thorught the piston :-X, ...but... when the tempurature of the mixture in the combustion chamber is reduced then it becomes really efficient. All you need is to have proper airflow, good intercooler, and heat guards and you will be just fine. The pistons from the montero are made of cast aluminum and will handle a great amount of abuse. When I got the 14.8 run I was going 91.23 mph, my 60" was 2.0123 and the 1000" was 13.03. All I know that if you are not breaking parts, you are not racing. ;D
P.S. It can handle 14 psi, if you dont think so, too bad.
