starion27 Posted August 2, 2009 Report Share Posted August 2, 2009 Ok so i just go the motor back in and now it wont start, I think it has something to do with the injectors cause I have spark and I have fuel but it's not making it into the motor and I think it has to do with the ground to the injectors, does anyone have any advice on what to check for. Link to comment Share on other sites More sharing options...
GAflatty Posted August 2, 2009 Report Share Posted August 2, 2009 will it start if you spray starting fluid below the injectors? Link to comment Share on other sites More sharing options...
starion27 Posted August 2, 2009 Author Report Share Posted August 2, 2009 will it start if you spray starting fluid below the injectors? Yes, I tried that jsut to make sure. Link to comment Share on other sites More sharing options...
GAflatty Posted August 3, 2009 Report Share Posted August 3, 2009 okay this happend to me... it isn't very comon and i am not trying to scare you but i had a bad ECU. first thing that i would do is if you have a "noid" light check and see if the signal is atleast getting to the injectors. if not check deeper in the curcuit. i ended up backprobing the wires coming from the ECU that sends the signal to the injectors and connected a test light and nothing happened on startup. so i barrowed a know good ECU from shift1313 (which i still need to return :sweatingitout: ) and sure enough it fired right up. so do your check and hopefully you won't need an ECU like me. because finding one (or getting mine rebuilt) at a price i am willing to pay is not easy. good luck and keep us posted. i will try to help as much as i can. Link to comment Share on other sites More sharing options...
