awdaniel Posted April 25, 2009 Report Share Posted April 25, 2009 Any ideas on why my AC compressor want engage. It's full of freon and was working great before it just stop. I think it's the AC relay but not sure how to test it. Also need to know the part number. I've been searching for it for 2 weeks. Its starting to get hot!!! The one they ordered at O'Reilys wasn't even close. AC Relay Link to comment Share on other sites More sharing options...
BrazilBoy Posted April 25, 2009 Report Share Posted April 25, 2009 I don't believe it is your relay most likely your dual pressure switch http://www.starquestclub.com/forum/index.p...nditioner+relay Link to comment Share on other sites More sharing options...
mikec Posted April 25, 2009 Report Share Posted April 25, 2009 The most common reason the A/C compressor won't enage is a busted overheat sensor switch - on the thermostat housing you'll see several electric and vacuum sensors. The upper-most electric one (and the physically smallest one) should have a single wire on it. Unplug the wire and ground it... see if your a/c works now. If so, that sensor is shot. It's an ON/OFF switch that normally connects the electrical prong/tank to ground as long as the engine is not overheating. That sensor tends to rot internally with age. If the tang wiggles/twists, that's proof the sensor has rotted. mike c. Link to comment Share on other sites More sharing options...
