Alspos Posted April 30, 2003 Report Share Posted April 30, 2003 Are the drive shafts compatible from model to model. ie if you put an 87 diff in a 83 model, can you use the original 83 drive shafts. I know the shaft diameters increased later on, and they went from 4 bolt to 5 then 6 bolt, but did the splines that go into the diff change? Any help would be appreciated. Thanks Link to comment Share on other sites More sharing options...
rjf Posted May 1, 2003 Report Share Posted May 1, 2003 Hello - There seems to be a bit of confusion here. There is a difference between the driveshaft used on a 5 speed from that used on an auto tranny. I am not sure, but I do not belive there is much else changed on the drive shaft. The rear axle shafts used 4 bolts to connect ot the outer CV joint until 88 when they were upgraded to 6 bolts. The non-intercooled cars all had 4 lug bolts, the intercooled cars (including the 85.5 flat sider) all had 5 lug bolts for the wheels. Hope that helps - Link to comment Share on other sites More sharing options...
Alspos Posted May 1, 2003 Author Report Share Posted May 1, 2003 Sorry, by drive shafts I meant from the differential to the wheels, not tailshaft (gearbox to diff) Sorry, us Aussies talk funny. I am after information on the splines on the drive shaft, size, number, that sort of thing going in to the differential. And whether you can swap an open centre for an LSD centre. Thanks Link to comment Share on other sites More sharing options...
