Starion_88 Posted February 17, 2004 Report Share Posted February 17, 2004 I'm hooking back up my stock stereo in my 88 Quest. I tried reading the wiring diagram but can't understand it. I just need to know which wires go together. WIRING DIAGRAM http://www.tristarion.com/htmlman/Electrical/electrical.html Page 249 Link to comment Share on other sites More sharing options...
emann420 Posted February 18, 2004 Report Share Posted February 18, 2004 http://www.starquestclub.com/index.pl?boar...;num=1075491868 post # 2 http://www.starquestclub.com/index.pl?boar...;num=1074540441 post #22 E-Mann Link to comment Share on other sites More sharing options...
Starion_88 Posted February 18, 2004 Author Report Share Posted February 18, 2004 http://www.starquestclub.com/index.pl?boar...;num=1075491868 post # 2 http://www.starquestclub.com/index.pl?boar...;num=1074540441 post #22 E-Mann I need to know what wires to connect for the stock harness to a stock harness. Link to comment Share on other sites More sharing options...
emann420 Posted February 18, 2004 Report Share Posted February 18, 2004 wires from car purpose Red/Black 12V+ Blue/White ACC + White/Black Power Antenna Signal + Green/White Illumination + there are two Black/Yellow Dimmer variable Light Green/Blue Left Front + Black/Blue Left Front - White/Red Right Front + Black/Red Right Front - Yellow/Blue Left Rear + Gray/Blue Left Rear - Yellow/Red Right Rear + Gray/Red Right Rear - Curtousy of indy85stariones Yellow/White -- SWC Output: Signal Wire Blue/White -- SWC Input: ACC + Black/White -- SWC Input: Use a ring terminal and attach to metal brace for ground Green/White -- this is the other illumination wire I'm assuming that you or someone cut the harness off and you need to reattach the wires to the factory radio plug. The wire colors should match up perfectly if you have the factory plug. If you dont have the factory plug anymore the harness that plugs into the radio is the American International DWH-611, then refer to the second link and the wire colors are there for matching up a non-factory harness to the factory wires. Good Luck E-Mann Link to comment Share on other sites More sharing options...
ZPI28 Posted February 22, 2004 Report Share Posted February 22, 2004 great info Eric, ill be using it on my Yellow quest since someone cut out the factory radio wires.. > On another note ,, how are those door pods coming? Steven Link to comment Share on other sites More sharing options...
