jtoneil Posted September 11, 2002 Report Share Posted September 11, 2002 Where have you guys been mounting your dome tweeters? Im thinking on that black traingle peice just above the door but Im open for suggestions. Im not sure where Im going to hide the inline crossover that comes with them. Somewhere inside the door I gues. Im open to all suggestions..Fire away John Link to comment Share on other sites More sharing options...
Distorted.Clarity Posted September 11, 2002 Report Share Posted September 11, 2002 i have 4 tweeters. two mounted on the top of the back hatch and i cut two holes for the tweeters right by where the door meets the dash in like with the windows controls. Link to comment Share on other sites More sharing options...
indy_85stariones Posted September 12, 2002 Report Share Posted September 12, 2002 I don't like cutting/drilling into my door panels. You could place your crossover inside your door (there is a cavity/crevise behind your power window switch) and attach your tweeter to the door/mirror sail pane (like you suggested). You could place your crossover immediately behind your headunit, remove your dash speakers, and place your tweeters in your dash speakers old location. ------------------------------------------ I chose to go another route. I put high-quality component speakers in the hatch -- tweeter mounted on window pillar and woofer in factory location. I adjusted them for maximum bass and highs. I put 4 inch speakers in the doors and clipped their tweeter. If you visualize a 3-way speaker... then I have woofer and tweeter in the hatch and midrange from the front. Link to comment Share on other sites More sharing options...
Mitsuracer1 Posted November 25, 2002 Report Share Posted November 25, 2002 I recommend the tweeters in the sail-pane Idea. The high end frequencies are the most crucial for getting them pointed in the right direction. (you want the center of the tweeter pointed just below the rear view mirror for best sound quality and staging). if you plan on using seperates in the rear I suggest putting the tweeter roughly 4-6" from the center of the woofer cone and bounce the sound off of the rear side widows at that distance the phase-shift wouldn't be noticable at all. that's how my system is set up. Have fun. Link to comment Share on other sites More sharing options...
