Eldos1 Posted March 25, 2003 Report Share Posted March 25, 2003 Ok, I am going to use a crank trigger which is perfect for cylinder pulse. Now the problem is that I need a reference for cylinder 1. I am also going to use an MSD DIS - 2 (Waste Spark) so not only do I need a pulse to fire the MSD, but I can just use an induction sensor on #1 plug wire. The Crank trigger will give #1 cylinder 2 times not just once per cycle. So, what are other people using to reference #1? Steve Gee Link to comment Share on other sites More sharing options...
Joel Posted March 25, 2003 Report Share Posted March 25, 2003 You don't need to Reference cylinder #1. You need a Sync trigger within several degrees of TDC. The SDS dual element is what I am using with the haltech E6k to run my mpi w/dis setup. Joel Link to comment Share on other sites More sharing options...
