Jeff_S. Posted November 15, 2002 Report Share Posted November 15, 2002 I was having a loud squeaking noise from the clutch pedal that i thought was either the worn out clevis and pin at the top or the master cyl. goin bad, but it turned out to be the stupid clutch helper spring making all the noise. all you have to do is take off one 12mm bolt hold the clutch on the floor and then pry the spring coil out of the bracket, not the pedal, it isnt super easy to do , but just get crazy with it and use a screw driver to help get it to move. i think this thing is what wears out the clevis and pin in the first place, from putting pressure on it from both ways and as soon as it gets worn then it starts slapping and is worse. the clutch pedal might be about 1lb heavier to push, doesnt affect the cruise, and i like the feel of it now instead of the dead airy feel with the spring screwin around with it. just my thought jeff s Link to comment Share on other sites More sharing options...
