1987 Mitsubishi Starion ESiR
Guest
$2800 in Huntsville, AL 256 513 6773
Cosmetically the body is pretty straight. The passenger rocker has a dent where a previous owner had jacked it up wrong. Same applies to the driver's side, only it's not on the rocker Clear is going on the roof, and clearcoat is gone on the hood. The front bumper had indentations from where it once had a front license plate. Minor spots where there is rust where the paint has chipped over the course of its life.
Good:
Has a 55lb and a 95lb Delphi injectors with the modified mixer housing.
Stock 12a turbo
2" hard pipes with crushed 1G DSM BOV.
2.5" exhaust with a magnaflow high flow ceramic cat and a Greddy Evo2 muffler.
88/89 seats
88/89 ECU inside the 87 case.
89 transmission
89 auto-down window switch
Autometer boost gauge.
Passenger side frame rail replaced
Replaced fuel filler hose
New tires front and rear
Bad:
No AC
Windshield is crack
E-Brake doesn't work, need to lub or replace the cables.
Edited by Guest
You should be asking $2900 for it. it has a rare 89 auto-down window switch. :)
This it a good running car.
Oh and the e-brake cables are there, but the e-brake dose not work.
Someone need to get this car.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
