"WASH" light stays on. QUICK FIX??
Stariontastic
I have two Starions. One '87 and one '88. The "wash" dash light is on in both cars (and has been since I bought them.) While driving the '88 the other night, the light went off a couple of times, possibly when hitting bumps in the road and came back on. Of course, checked the front and back fluid levels in both cars and the lights are still on in both. I'm sure there must be a sensor in each tank. Probably would be good to replace them if they are available. This must be a common problem if both cars are doing the same thing. If anyone has any advice as far as availability or replacement tips or if the sensors are even at fault for the newbie, I'd really appreciate it!
Brian
Its switch under the paintjob that is forced closed when too much dirt is on the car. Wash it and light should go off..
Actually sorry man just messing here is the answer
http://www.starquestclub.com/forum/index.php?showtopic=135665
I say ditch the sensors and just ground them out.
Edited by JohnnyWadd
I know! The car is clean so the light should go out, right? I did a little research and found the front tank is the only one with a sensor. I'm going to ground the white / blue wire that goes to the to the sensor and that annoying light should go out.
Pulled the battery, tray and washer tank today. On the bottom, there is a sending unit (float) for the "wash" light. Pulled the rubber unit out of the tank and it's basically disintegrated inside. I reinstalled it in the tank and pulled one of the sending unit's wires from the 4 pin connector that is located by the corner above the battery tray. I pushed the tab on the terminal to pull it out of the connector and taped it off so that it could be put back in if necessary. No cut wires and the light is OFF. Glad I pulled the tray too, pretty nasty with road debris underneath. The car will be a little faster now with the dirt gone.
Excellent!!
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
