Munkee Posted July 29, 2013 Author Report Share Posted July 29, 2013 bump Quote Link to comment Share on other sites More sharing options...
superquest Posted August 2, 2013 Report Share Posted August 2, 2013 I would be in to it for a trade or possibly $500 Quote Link to comment Share on other sites More sharing options...
Munkee Posted August 4, 2013 Author Report Share Posted August 4, 2013 bump. giving till the end of the month then i start parting her out. Quote Link to comment Share on other sites More sharing options...
Munkee Posted August 12, 2013 Author Report Share Posted August 12, 2013 bump Quote Link to comment Share on other sites More sharing options...
Roush Posted August 12, 2013 Report Share Posted August 12, 2013 If this car were closer I would definitely get it... Quote Link to comment Share on other sites More sharing options...
Munkee Posted August 18, 2013 Author Report Share Posted August 18, 2013 Buy me! Quote Link to comment Share on other sites More sharing options...
Munkee Posted August 25, 2013 Author Report Share Posted August 25, 2013 TTT Quote Link to comment Share on other sites More sharing options...
Starquest_Shopper Posted August 26, 2013 Report Share Posted August 26, 2013 I'm in the same spot as the others that are so far away. I'll throw out an idea and see what you think-I'm planning an engine swap and don't need the motor or trans (or the suspension goodies or even the stereo) but do need a solid low-cost rolling shell w/ sunroof. I see in your latest CL ad you're considering this, but don't want to. As far as the wheels go, if you could throw on 4 junkyard wheels/tires, that would be fine. I went to car-part.com and it looks like a set from an Eclipse can be had for around $35 each in your area. I know parting cars is no fun and takes a while to make money if you ever do. If you decide on pulling the motor/trans & putting stock suspension bits on it and selling the roller let me know. That way you could pallet & sell the motor & trans and the other stuff could go by UPS and would be a lot easier to sell. I'm looking into some others in the Southeast but thought I'd throw out this idea since your car keeps coming up on my CL searches. Quote Link to comment Share on other sites More sharing options...
Munkee Posted August 26, 2013 Author Report Share Posted August 26, 2013 (edited) If I part it out the plan is to pull the parts easiest to pull first and work my way in. Stock suspension has already been put back on except for the bushings i left those in. Next to go will probably be the front air dam, turbo, manifold, and TBI pieces. Will eclipse wheels fit our cars? I've been looking for a set of steelies but not sure which ones will fit on the car. Edited August 26, 2013 by Munkee Quote Link to comment Share on other sites More sharing options...
Starquest_Shopper Posted August 27, 2013 Report Share Posted August 27, 2013 Will eclipse wheels fit our cars? I've been looking for a set of steelies but not sure which ones will fit on the car.This chart shows later model DSMs:http://www.discountedwheelwarehouse.com/Mitsubishi___Vehicle_Bolt_Pattern_Reference.cfm The 2000+ Eclipse (as well as about all of the others) use the 5x114.3 pattern. The older cars like the SQ are here, it's the same pattern for the 5 lug cars:http://lugpattern.net/Mitsubishi_Bolt_Patterns.htm Here are some others:http://wiki.answers.com/Q/What_cars_use_5x114_bolt_pattern You may need to consider the hub diameter as well as the bolt circle.The initial list I found for that bolt pattern is:Acura TSXChrysler Concord/IntrepidDodge CaravanFord MustangHonda Accord, S2000, CRV, CivicHyundai TiburonInfinity G35Mazda 3, RX8Mitsubishi Diamante ('99+), 2G Eclipse, 3000GTEagle talon 1990-98 Base, ESI, TSI ModelsNissan 300ZX, 350Z, Altima, Maxima, QuestToyota Camry, AvalonLexus ES300, ES330, IS250, IS350, GS300, GS400, LX47008+ Scion xB Quote Link to comment Share on other sites More sharing options...
Starquest87Jimmy Posted September 3, 2013 Report Share Posted September 3, 2013 Mustang Wheels are the same lug pattern size. I used the spare on my car when it had a flat. Quote Link to comment Share on other sites More sharing options...
