bboyrez Posted January 22, 2013 Report Share Posted January 22, 2013 Well i have just the game for you. So the more digging around in the engine bay i do the more i realize everything is missing. again up to this point i have done what i can, but the manuals are a little hard for me to pinpoint exactly which part it is im searching for. ive uploaded the pictures to photobucket. so without further adu.... enjoy my wreckage that is my winter project http://i1290.photobucket.com/albums/b528/Mike_Rez_Sherwood/20130122_133614_zpsbb884a16.jpghttp://i1290.photobucket.com/albums/b528/Mike_Rez_Sherwood/20130122_133627_zpsada8119c.jpgthe next one is one of my biggest worries at the moment because the big area that is emptyhttp://i1290.photobucket.com/albums/b528/Mike_Rez_Sherwood/20130122_133631_zpse24f5f8b.jpgobviously if something is mentioned in another picutre dont feel the need to re-post it but in terms of this picture im looking for what is missing along the right side of the picture where the free line ishttp://i1290.photobucket.com/albums/b528/Mike_Rez_Sherwood/20130122_133825_zpsac0c8254.jpgfor the next picture there is a bolt "88". the obvious side of me says the part touching it goes in there. But what reason would there be to not keep it hooked up.http://i1290.photobucket.com/albums/b528/Mike_Rez_Sherwood/20130122_134052_zps4947a7f6.jpgthe part that i'm holding, im not sure what this does or if i can fix this myself or if i have to just get another part, but it looks broken to me and before i mess with this i'd just like a little idea of what that is im messing withhttp://i1290.photobucket.com/albums/b528/Mike_Rez_Sherwood/20130122_134251_zps0877b978.jpgthis is inbetween the engine bay and the front air dam, it looks like this would be the hydrolic line for the lights to move up and downhttp://i1290.photobucket.com/albums/b528/Mike_Rez_Sherwood/20130122_134356_zps374416a3.jpglooking around in the void i found this bottom portion sawed off.. and i am at a complete loss for why. im not even 100% sure what it ishttp://i1290.photobucket.com/albums/b528/Mike_Rez_Sherwood/20130122_134605_zps9015f9f6.jpgLastly while looking around a found something dangling (the tan piece) i know its blurry but the wind started blowin up like a bazookahttp://i1290.photobucket.com/albums/b528/Mike_Rez_Sherwood/20130122_134858_zpsdc79c8f6.jpgand a little further outhttp://i1290.photobucket.com/albums/b528/Mike_Rez_Sherwood/20130122_134902_zps5676ad18.jpg Quote Link to comment Share on other sites More sharing options...
bboyrez Posted January 22, 2013 Author Report Share Posted January 22, 2013 i dont know why it posted some pictures upside down but on my photobucket they're correctly turnedhttp://s1290.beta.photobucket.com/user/Mike_Rez_Sherwood/library/ Quote Link to comment Share on other sites More sharing options...
dmyers151 Posted January 22, 2013 Report Share Posted January 22, 2013 Oh lordie... For starters that big gaping hole is where your ABS module used to be, it's alright that it isn't there anymore. You're missing the O2 sensor, that's the hole in that plate just behind your turbo. Unless you removed them, your injectors are gone. That's the two holes on the drivers side of the motor. Downpipe, gone. That's the cutoff tube just below your turbo. Put an R-pin in your wastegate actuator arm end, that's the little rod that runs back from the front of the turbo. That open ended line near the radiator is for your AC system, it's likely gone. No worries there for the time being. That random bolt in the brake master cylinder is a joke. I'd say hook that line up to it, but god knows if there's anyone home on the other end. You need to bend up a line that goes from where the bolt is, to the brake distribution block on the firewall just below there. I believe its a 10mm fitting, you'll need like 30" of brake line. Quote Link to comment Share on other sites More sharing options...
dmyers151 Posted January 22, 2013 Report Share Posted January 22, 2013 http://i471.photobucket.com/albums/rr71/dmyers151/20130122_133825_zpsac0c8254_2.jpg Quote Link to comment Share on other sites More sharing options...
dmyers151 Posted January 22, 2013 Report Share Posted January 22, 2013 http://i471.photobucket.com/albums/rr71/dmyers151/20130122_134605_zps9015f9f6_2.jpg Quote Link to comment Share on other sites More sharing options...
dmyers151 Posted January 22, 2013 Report Share Posted January 22, 2013 I'd do more but I'm at work and that should keep you busy for a little while. I see Justin's in here typing so I'm sure he'll set you straight on the rest. Good luck, we've all been where you are at some point. Quote Link to comment Share on other sites More sharing options...
bboyrez Posted January 22, 2013 Author Report Share Posted January 22, 2013 thanks i appreciate it, anything else would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Coke Posted January 22, 2013 Report Share Posted January 22, 2013 Damn Dale. I love your pics! So much effort, but it makes it easy. Good work! Dale's right on the money. PCV, Injectors, o2 Sensor, ABS, downpipe, all missing. Also seen a couple bolts missing, and a plug for your ISC is destroyed. Is it in the vehicle harness side of the connector, or on the sensor side? Quote Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted January 22, 2013 Report Share Posted January 22, 2013 (edited) That random bolt in the brake master cylinder is a joke. I'd say hook that line up to it, but god knows if there's anyone home on the other end. You need to bend up a line that goes from where the bolt is, to the brake distribution block on the firewall just below there. I believe its a 10mm fitting, you'll need like 30" of brake line.with that bolt set up you have to back breaks and the ac delete that was done is a super half-tail job Edited January 22, 2013 by 88-cnqst-tsi Quote Link to comment Share on other sites More sharing options...
bboyrez Posted January 23, 2013 Author Report Share Posted January 23, 2013 with that bolt set up you have to back breaks and the ac delete that was done is a super half-tail jobmy question is why the hell would you bolt it up though? Quote Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted January 23, 2013 Report Share Posted January 23, 2013 my question is why the hell would you bolt it up though?to make it not leak out of the hole probably but you got allot of fixing to do so heres some links for ya http://koquest.homestead.com/ABSRemoval.htmlhttp://www.starquestclub.com/forum/index.php?showtopic=134659http://www.starquestclub.com/forum/index.php?showtopic=134352http://www.starquestclub.com/forum/index.php?showtopic=134353http://www.starquestclub.com/forum/index.php?showtopic=28069http://www.starquestclub.com/forum/index.php?showtopic=134424&hl=%2Bcleaning+%2Bseat+%2Bbeltshttp://www.starquestclub.com/forum/index.php?showtopic=135234http://starquest.i-x.net/viewtopic.php?t=1180&sid=7c7e5d3dc6b91077db17ca052f11c7f6http://starquest.i-x.net/viewtopic.php?t=1031 Quote Link to comment Share on other sites More sharing options...
dmyers151 Posted January 23, 2013 Report Share Posted January 23, 2013 Damn Dale. I love your pics! So much effort, but it makes it easy. Good work! Dale's right on the money. PCV, Injectors, o2 Sensor, ABS, downpipe, all missing. Also seen a couple bolts missing, and a plug for your ISC is destroyed. Is it in the vehicle harness side of the connector, or on the sensor side? Haha, thanks buddy. I just threw them together with MS Paint while I was between things at work. I think they came out nice, should be pretty helpful. Quote Link to comment Share on other sites More sharing options...
bboyrez Posted January 23, 2013 Author Report Share Posted January 23, 2013 (edited) dmyers- they were very helpful i really appreciate it. If only all of the tutorials and whatnots came like that haha. 88- thanks for the links, those will keep me busy for awhile for sure Edited January 23, 2013 by bboyrez Quote Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted January 23, 2013 Report Share Posted January 23, 2013 (edited) how much did you get your car for and i did an ac, cruse control and aboout to do a abs delete so if you need parts i got em also give me a list of parts ya need and ill keep an eye out for them Edited January 23, 2013 by 88-cnqst-tsi Quote Link to comment Share on other sites More sharing options...
bboyrez Posted January 23, 2013 Author Report Share Posted January 23, 2013 (edited) $1000im going to do the ac delete tomorrow, i was concerned about the abs delete because ive never had a car without it but looking around at explanations why you would do an abs delete, -alot of times it says it increases handling and makes your breaking better/more effective. so i think im going to go along with that delete. im meeting up with coke sometime in the near future to see what he can give to me for this project. at this point everything that i know i need has been posted in this page (aside from an interior that im waiting until the end to do) Edited January 23, 2013 by bboyrez Quote Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted January 23, 2013 Report Share Posted January 23, 2013 (edited) thats a fair price and ac is a bit of a pain to delete only cause the small hardline is a b1tch to get out and if you wanna keep the ac you might want to take all the lines out and clean then since they have been sittng without any plugs theres probably s*** in them, the abs is bs in the quest because its only rear wheel and a bulcky set up so just do a proper delete also your luckey you get a fellow quester to help out lol im in the quest dead land Edited January 23, 2013 by 88-cnqst-tsi Quote Link to comment Share on other sites More sharing options...
bboyrez Posted January 23, 2013 Author Report Share Posted January 23, 2013 (edited) haha yeah tell me about it. i'd be screwed without even the forum and the people helping me. where in canada are you? i go to kingston and toronto often, well used to haha Edited January 23, 2013 by bboyrez Quote Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted January 24, 2013 Report Share Posted January 24, 2013 haha yeah tell me about it. i'd be screwed without even the forum and the people helping me. where in canada are you? i go to kingston and toronto often, well used to hahahahaha far from there im on the west side in B.C Quote Link to comment Share on other sites More sharing options...
