stacyLynn Posted December 31, 2012 Report Share Posted December 31, 2012 (edited) Can someone point me in a direction to figure this out. OK the car ran fine until I had to replace the intake manifold I went ahead and rebuilt the throttle body, replaced the steering gear box, thermostat and belts. Also replaced the the valve cover gasket.. NOW. I can't get it to start. It's driving me nuts. What am I missing? This is my first project car that I am trying to do by myself. Any suggestions would be appreciated! Edited December 31, 2012 by stacyLynn Quote Link to comment Share on other sites More sharing options...
Ironside Posted December 31, 2012 Report Share Posted December 31, 2012 When you try and start it does the tach jump? Quote Link to comment Share on other sites More sharing options...
stacyLynn Posted December 31, 2012 Author Report Share Posted December 31, 2012 (edited) Yes... I did have to take the distributer out to get to a bolt. Could I have screwed up putting it back in.? Edited December 31, 2012 by stacyLynn Quote Link to comment Share on other sites More sharing options...
stacyLynn Posted December 31, 2012 Author Report Share Posted December 31, 2012 Bump Quote Link to comment Share on other sites More sharing options...
DMNDSTAR87 Posted December 31, 2012 Report Share Posted December 31, 2012 (edited) I don't see anything on your list that would require you to pull the dizzy to get to a bolt but if it was reinstalled wrong that is definately a problem...anyways always check easy things first...r u getting fuel? How bout spark? Did u make sure all sensors were plugged back in when u reinstalled throttle body to the intake? Injector clips reinstalled on the right injectors?I'm sure your MPS/ISC are way out of adjustment along with your TPS.check things 1at a time and eliminate items till you find the culprit..Gig out Edited December 31, 2012 by DMNDSTAR87 Quote Link to comment Share on other sites More sharing options...
Ironside Posted December 31, 2012 Report Share Posted December 31, 2012 Do you have a timing light? Quote Link to comment Share on other sites More sharing options...
stacyLynn Posted December 31, 2012 Author Report Share Posted December 31, 2012 I have a timing light. That's my next step. I'm sure it's something simple. Quote Link to comment Share on other sites More sharing options...
stacyLynn Posted December 31, 2012 Author Report Share Posted December 31, 2012 I took the distributer out to get to a nut on the bottom of the intake. Someone before me bugared up the wiring found some wires that have broken off. Wish people would do sh**t right. Not half a** grrrr Quote Link to comment Share on other sites More sharing options...
