Spoolin88 Posted August 23, 2010 Report Share Posted August 23, 2010 (edited) Ok i just bought a 16g and its in the process of getting rebuilt, i was wondering how hard thid is going to be to put on. Pretty much im asking "What do i got to do?" Like peices i have to buy, running oil lines. if anybody could give me a step by step of what i need to do and what extras i need to buy, it would be greatly apreciated ThanksDustin Edited August 23, 2010 by Spoolin88 Link to comment Share on other sites More sharing options...
dmyers151 Posted August 23, 2010 Report Share Posted August 23, 2010 Did you get a Starion/Conquest specific 16g, or a DSM 16g? Link to comment Share on other sites More sharing options...
Scotty Dont Posted August 23, 2010 Report Share Posted August 23, 2010 Did you get a Starion/Conquest specific 16g, or a DSM 16g? Ditto 16g is just the compressor wheel and has no bearing on the exhaust wheel, compressor and exhaust housings, and oil feed and return lines. Link to comment Share on other sites More sharing options...
carguygibby Posted August 23, 2010 Report Share Posted August 23, 2010 If it's in a 12a housing you just slap it on!If it's in a different housing you may have to ream out the manifold a little.Colinhttp://www.starquestclub.com/forum/public/style_emoticons/default/cool.gif Link to comment Share on other sites More sharing options...
intense98rt Posted August 23, 2010 Report Share Posted August 23, 2010 Depends on what type of 16g you have. What did it come off from? I'm guessing not a starquest.If your 16g is at a shop then you should take in the exhaust housing from your stock turbo. Tell them you need it opened up and made to fit the tdo5h exhaust wheel from the 16g. I did mine myself. After you get it back you will need to clock the compressor housing so that the outlet will face in the correct direction. Mine had a pin in the cartridge and a grove in the housing so it couldn't turn. I used a dremel to make a grove where I needed it. Next you need to figure out a wastegate. I used the one that came with my 16g and modified it to fit. Oil and coolant fittings should bolt in no problem. Use new washers. Link to comment Share on other sites More sharing options...
Spoolin88 Posted August 24, 2010 Author Report Share Posted August 24, 2010 (edited) yeah its a TD05 EVO III. i would like to have my 12a turned into one but not for 600+. Thanks for all the help guys. Dustin Edited August 24, 2010 by Spoolin88 Link to comment Share on other sites More sharing options...
dmyers151 Posted August 24, 2010 Report Share Posted August 24, 2010 So it's a DSM turbo? Post up some pics. If it is a DSM unit, using that turbo would require modifications to your exhaust manifold, downpipe, and turbo to intercooler pipe. Link to comment Share on other sites More sharing options...
Komeuppance Posted August 24, 2010 Report Share Posted August 24, 2010 Get your stock 12a exhaust housing machined out and the compressor housing. Then you can bolt on and go. -Robert Link to comment Share on other sites More sharing options...
Scotty Dont Posted August 24, 2010 Report Share Posted August 24, 2010 So it's a DSM turbo? Post up some pics. If it is a DSM unit, using that turbo would require modifications to your exhaust manifold, downpipe, and turbo to intercooler pipe. Get your stock 12a exhaust housing machined out and the compressor housing. Then you can bolt on and go. -Robert Either one will work but Komeuppance's way is WAY easier Link to comment Share on other sites More sharing options...
Spoolin88 Posted August 24, 2010 Author Report Share Posted August 24, 2010 Yeah im going Komeuppance's way. Thanks for all the halp guys, i know everyone gets tired of hering the same questions over and over again. I searched for a topic close to this one but the search bar isnt much help. thanks againDustin Link to comment Share on other sites More sharing options...
Komeuppance Posted August 25, 2010 Report Share Posted August 25, 2010 G-g-g-go. I wonder how much machining will cost... -Robert Link to comment Share on other sites More sharing options...
BMWTech Posted August 25, 2010 Report Share Posted August 25, 2010 Any reputable turbo shop can do the machining and balancing in the $100 range. The only thing that will drive the price up a little is how much you have the inlet/outlet portions of the compressor housing ported. Link to comment Share on other sites More sharing options...
Spoolin88 Posted August 25, 2010 Author Report Share Posted August 25, 2010 Yeah im going to call today and see how much machining cost. the low 100s range is fine but when they guy said over 600 to upgrade the 12a i was thinking WOW. Dustin Link to comment Share on other sites More sharing options...
BMWTech Posted August 26, 2010 Report Share Posted August 26, 2010 Make sure you check what 16g compressor wheel you have, that will make a big difference on the amount of machining needed. A S16g wheel has a superback design which requires the center cartridge to be machined also and the rebuild kit is different. You can identify this by looking at the back of the compressor wheel if it has a curve to it, it's a S16g, if flat it's a 16g. You can also look up the inducer/exducer specs and measure the wheel. Link to comment Share on other sites More sharing options...
Spoolin88 Posted August 26, 2010 Author Report Share Posted August 26, 2010 Make sure you check what 16g compressor wheel you have, that will make a big difference on the amount of machining needed. A S16g wheel has a superback design which requires the center cartridge to be machined also and the rebuild kit is different. You can identify this by looking at the back of the compressor wheel if it has a curve to it, it's a S16g, if flat it's a 16g. You can also look up the inducer/exducer specs and measure the wheel. Its not an S16g. Dustin Link to comment Share on other sites More sharing options...
Komeuppance Posted August 26, 2010 Report Share Posted August 26, 2010 He's using the entire 16g center section inside stock 12a exhaust/compressor housings. 16g's and up have superback wheels, but he's using the entire center section. -Robert Link to comment Share on other sites More sharing options...
