Turbo_84_Starion Posted August 23, 2010 Report Share Posted August 23, 2010 What's the starter bolt thread pitch?Also, what length bolts do I use with the A/C delete alternator bracket? Link to comment Share on other sites More sharing options...
Frenchi934 Posted August 23, 2010 Report Share Posted August 23, 2010 (edited) What's the starter bolt thread pitch?Also, what length bolts do I use with the A/C delete alternator bracket? starter bolt thread pitch is 1.25 mm on my car i believe.... and for the timing cover on my car I had a bolt missing that was filled nicely with a 60mm bolt EDIT: realized you were talking about a bracket that supports the alternator without the A/C compressor. but left the timing cover info up in case it still helps Edited August 23, 2010 by Frenchi934 Link to comment Share on other sites More sharing options...
Turbo_84_Starion Posted August 24, 2010 Author Report Share Posted August 24, 2010 Thank you, it was M10x1.25 60mm bolts for the starter. I still don't know what size bolt for the alternator but some trial and error will have to do. Link to comment Share on other sites More sharing options...
