miamipops Posted April 30, 2010 Report Share Posted April 30, 2010 Are mookeeh struts side specific? GS2 and GS3 which is reght side and which is left side?thanksPete Link to comment Share on other sites More sharing options...
Tik Posted April 30, 2010 Report Share Posted April 30, 2010 Unless they have brackets on them specific to a side struts can generaly go either way. so if you cant tell by looking at them that one has a bracket on the left and the other on the right side then your good. Link to comment Share on other sites More sharing options...
miamipops Posted April 30, 2010 Author Report Share Posted April 30, 2010 Unless they have brackets on them specific to a side struts can generaly go either way. so if you cant tell by looking at them that one has a bracket on the left and the other on the right side then your good.thanks Link to comment Share on other sites More sharing options...
mquester Posted April 30, 2010 Report Share Posted April 30, 2010 they are specific, look at the bottom for a notch in them the notch goes to the back side of the car you will see when you take the old ones out, beware of the brackets, I had to work on mine a little as the welded on nut was offcenter. Link to comment Share on other sites More sharing options...
miamipops Posted April 30, 2010 Author Report Share Posted April 30, 2010 they are specific, look at the bottom for a notch in them the notch goes to the back side of the car you will see when you take the old ones out, beware of the brackets, I had to work on mine a little as the welded on nut was offcenter.Thank you mquester Link to comment Share on other sites More sharing options...
