Jcizzle61 Posted April 5, 2010 Report Share Posted April 5, 2010 I tried to get my car started today after the long winter and I came across a dead battery. I charged the battery and tried starting it but it just kept turning over, then the headlamps would go up and go back down. I have no idea what this could be and need some help. Link to comment Share on other sites More sharing options...
alp247 Posted April 5, 2010 Report Share Posted April 5, 2010 Your battery it dead..go get a new one. Even if you charged the battery it will probably not hold a charge so just go get a new one and hook it up. after you hook it up you should run the car and check the volts from the termials to make sure your alternator is still up to par. Link to comment Share on other sites More sharing options...
Indiana Posted April 6, 2010 Report Share Posted April 6, 2010 Got some starter fluid? First test for ignition spark, place the coil wire from the dist. cap on the negative battery cable and turn the key to the start position. Did you have a spark there?See if you have fuel pressure, key in start position and have someone listen near the fuel tank. If you have an 84-87 and a dead plastic ignitor the fuel pump will not come one. If the fuse link that says ECI by the battery is dirty the fuel pump will not turn on. Link to comment Share on other sites More sharing options...
