Star_V8_Quest Posted September 21, 2006 Report Share Posted September 21, 2006 Ok,what kind of engine to swap over into the Palermo?It can only be 1 of the following:FordChrysler4g63and why ? Link to comment Share on other sites More sharing options...
MainstreaM Posted September 21, 2006 Report Share Posted September 21, 2006 4g63 It's easier to find than you think. Lots of good solid engineering from mitsu and aftermarket. It is the "smallblock" of the import world. You can use the factory trans, flywheel, pressure plate, and clutch. Stay true to the mitsu roots. Almost no fab with the right used factory parts. The thermostat issue may be solved (see www.projectzerog.com). You've got some folks relatively close doing the swap (me and brandon-->pr4mnceman) Chryslerlots of fab work, no turbo (factory anyway). FordYou've got one why do it again? Link to comment Share on other sites More sharing options...
Crazy larry Posted September 22, 2006 Report Share Posted September 22, 2006 MMMMMM MOPAR Because I got one and you don't Link to comment Share on other sites More sharing options...
